Results 1 to 10 of 14
    Nov 2020
    Default 2017 Supra SA Fluids
    Prepping to do an oil change and check all other fluids and top off accordingly (except coolant ).
    I have the raptor 400 and it looks like indmar 5w30 is best. How much does the engine take? Anyone else recommend better oil?
    I’m certain I have a cartridge filter which would be 501022S part from indmar. Right?
    Lastly, what about transmission and such. That’s where I’m lost. I want to make 100% sure I top off with correct fluids. Thanks!
    May 2018
    Castrol 03084C Edge 5W-30 Advanced Full Synthetic Motor Oil, 5 Quart https://www.amazon.com/dp/B00ICSWGJ0...ing=UTF8&psc=1
    Because it’s a full synthetic and cheaper than indmar (rebranded) semi synthetic.
    I also prefer the WIX xp filter
    For the V drive, most run Mobil Delvac 1 sae 50 synthetic. Although you don’t need a gallon, Indmar v drive is synthetic and not too expensive
    Mobil Delvac Syn Transmission 50, 1 gal https://www.amazon.com/dp/B06XD2WVC7...QT1Q9X7665QPNH
    Transmission run any dexron 3 synthetic. Indmar atf is synthetic and not terribly overpriced for the amount you need.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Nov 2020
    Thanks brother. Also….wrong thread. My bad!
    Nov 2020
    When using a fluid extractor, do you prefer to extract through dipstick or oil drain hose through transom?
    Mods please move To service if possible. Thanks!
    May 2018
    Quote Originally Posted by eder10986 View Post
    Drain hose because it’s easy, you get all the oil and that is what the hose is for. Plus, it’s way faster than dipstick hose and so many get dipstick extractor stuck in the dipstick tube.
    Couple options on where to route extractor/drain hose.
    1) push ballast bag aside and put towel down in the rear starboard storage bay.
    2) if you have the surf locker engine cover off, you can route drain hose out the surf locker and put the extractor on the ground.
    2021 Supra SA 400
    Michigan
    Nov 2020
    Thanks! Makes total sense. Doing it this weekend.
    May 2018
    Make sure the engine oil is warmed up.
    You can use a 1/4 inch air hose fitting to connect your extractor to the factory drain hose.
    2021 Supra SA 400
    Michigan
    Nov 2020
    Great idea! I have a bunch of those at home. Thanks man!
    Apr 2013
    Knoxville TN
    I use the same stuff on my SL
    2018 Supra SL400
    Apr 2013
    Knoxville TN
    Same oil, filter, and fitting.
    2018 Supra SL400
