Results 1 to 9 of 9
Thread: Makai flow 3 tab stuck down.
05-20-2021, 11:13 PM #1
Anyone had this issue? I have turned the batteries on and off, reset tabs in the software and switched surf sides back and forth.
2021 Makai 450
2012 mojo 2.5 (sold)
2000 Crownline 202 (sold)
05-20-2021, 11:18 PM #2
Oof! Not sure what to tell you on that. How many hours you got on the boat? I have a 2021 Makai with only 11 on it. Color seems to be just like yours too. On bottom anway. I hope that's not contagious.
Sent from my moto z4 using Tapatalk2021 Moomba Makai
05-20-2021, 11:30 PM #3
22 hours on the boat, I first noticed it would turn better one way than the other when picking up a surfer
2021 Makai 450
05-21-2021, 10:52 AM #4Senior Member
- Aug 2011
- 2,522
2002 Moomba Mobius LSV - Sold
2006 Moomba Mobius LSV - Sold
05-21-2021, 06:22 PM #5
Ok, thanks for the advice. Dealer said they have time to look at it in 5 weeks, lol.
And they said it "might" be under warranty being it already 20 hrs old.2021 Makai 450
05-21-2021, 08:14 PM #6
Hours has nothing to do with it. You have 5 years warranty on parts and 5 to 7 years (if you got incentive deals) on the Engine covered by Indmar.
https://www.moomba.com/assets/protec...a-warranty.pdf
https://www.moomba.com/assets/protec...ake-series.pdfLast edited by haknslash; 05-21-2021 at 08:20 PM.
2019 Moomba Max "MOOMBAE"
2016 Yamaha AR192 - sold
05-21-2021, 09:25 PM #7
Yeah man. Unless you hit something and physically broke it, I would hope 20 hours is nothing!
05-22-2021, 09:41 AM #8Senior Member
- Apr 2002
- 195
Hey man. A couple ideas...did you try and reset "yaw" tab? Or just reset main tab? They are 2 different reset buttons. You have to scroll down to get to yaw tab. The actuator could be bad but it's more likely an issue with displacement integration. If you had a lot of weight In boat then yaw tab would have gone down. But if you had drained ballast before retracting then it might have stayed down. Kinda complicated but try reset and that should let you know if actuator is operational or not.
Matt Brown
Product Development Manager
05-22-2021, 11:07 AM #9
Thanks for the reply! I did notice once that day the displacement meter in the center of the autowake screen had gone down to zero when I was full of ballast and was surfing.
I will look for the yaw reset, thanks again!2021 Makai 450
