Thread: Wake Plate
    Feb 2007
    Orange County, CA
    Default Wake Plate
    This may be a dumb question but should my wake plate be moving to the "up position" after I have it completely down? This happens when I am approching full speed...
    I wouldnt think so. Maybe it is low in fluid and going up when all that water pressure is hitting it under speed.
    ________
    Yamaha DS7
    Aug 2006
    The Netherlands
    Default Re: Wake Plate
    Quote Originally Posted by Pike
    Don't know that but i think it is a good idea if yo swap the fuelmeter with the wakeplate meter in your dashboard. that way you alway have straight vision on your perfectpass and wakeplate.
    I did that to.
    Oct 2005
    Either low in fluid or you have a leak. Mine did that and it had a leak on the fitting to one of the pistons. Check your bilge for tranny fluid.
    Feb 2003
    Maryville, TN
    Check for leaks first. If no leaks, your pump is not working right. There is a "plunger" type piece in the pump that might not be sealing right.
  1. Wake plate for LS
    By mobyatBelews in forum General Chat
    Last Post: 02-28-2009, 10:58 AM
  2. Wake plate help!
    By lift yer skirt in forum General Chat
    Last Post: 06-11-2007, 12:06 AM
  3. Wake plate
    By clark in forum Wakeboarding | Wakeskating
    Last Post: 01-27-2005, 10:51 PM
  4. Wake Plate
    By latchkey in forum Wakeboarding | Wakeskating
    Last Post: 06-11-2004, 11:50 PM
  5. wake plate
    By 55ChevyBrad in forum General Chat
    Last Post: 11-08-2003, 02:57 AM
