Results 1 to 10 of 71
Thread: Freezing Temps
02-12-2021, 01:48 PM #1
Freezing Temps
With most of the country already at or below freezing I might be late in asking this question but do any of you run a bilge heater? I had my boat winterized at the dealer in November.....that being said should I be worried about anything with the boat with these freezing temps we are about to get?
2019 Makai
Raptor 450 w/ 1.76 Trans
WakeMakers 1350s in the rear & 1K in Lead
02-12-2021, 02:19 PM #2
Yes, it's gonna drop real low Monday.
Winterizing is pretty easy, just follow this doc I made.
https://drive.google.com/file/d/1hmk...w?usp=drivesdk
Hit me up if you want a hand this weekend.
Sent from my Note 9 using Tapatalk2017 Moomba Craz Surf Edition
02-12-2021, 02:23 PM #3
We winterized but I still might have Cody drop a small space heater in the boat on low with a Christmas light timer. Problem is you cannot rely on power remaining on. A friend drove through the hill country yesterday and said he saw multiple power lines down due to ice.
02-12-2021, 02:24 PM #4
02-12-2021, 02:27 PM #5
02-12-2021, 02:32 PM #6
02-12-2021, 02:42 PM #7
I always have my boat winterized and then summerized at the same time by my dealer here in DFW so I don't have to take it back in the Spring.
Do yall recommend putting an electric space heater inside the boat under the cover in this situation?2018 Supra SL550 with 850lbs of lead wake
2017 Supra SA400 (Sold)
2021 GMC Denali 2500
Soulcraft Vodoo
Soulcraft Jordi Pro
Soulcraft Super AV
Phase Five Matrix
02-12-2021, 02:46 PM #8
Stay warm, stay safe, and stay off the roads.
I'm definitely staying put Monday after the horrible pileup in Ft. Worth.
Katy,
Special Weather Statement until FRI 1:30 PM CST
Action Recommended
Avoid the subject event as per the instructions
Issued By
Houston/Galveston - TX, US, National Weather Service
Affected Area
Inland Harris County
Description
Three winter storm complexes will move through the region. The first of the 3 systems will be arriving early Saturday evening and overnight. Near freezing temperatures will be in place with a threat of freezing rain and sleet. Precipitation amounts should be light but even so icy roads will be issue especially along and north of a line from Bellville to Conroe to Livingston. The second system is likely to bring record-setting cold to the region. Bitterly cold air will be moving into the region behind an Arctic cold front Sunday night into Monday morning. Temperatures will abruptly plummet below freezing with strong gusty northerly winds. Freezing rain changing over to snow is likely with this system. Prolonged periods of freezing temperatures are expected with low temperatures Tuesday morning 5 to 15 degrees. The combination of both the cold temperatures and winter precipitation have the potential to significantly impact life and property. Travel will be severely impacted by hazardous icy and snowy road conditions. Sporadic power outages will be a possibility. Pipes and sprinkler systems may burst if not properly cared for in advance. Do so now! You should plan to stay put for at least a day given where you are Sunday night because travel may be extremely hazardous Monday. Hypothermia will be a possibility for those not dressed appropriately. Brutally cold wind chill readings of -7 to 10 degrees will be likely Monday through Tuesday morning. Remember the 4 P's: pipes, people, pets and plants. In addition, be aware of space heater dangers if not properly placed/used. The third system arrives sometime Wednesday and could bring another round of freezing rain or snow the region and continuing the cold weather though not as cold as Monday night and Tuesday morning it will continue the winter hazards. Confidence on timing and impacts is lower on this system given the potential for an extensive snow cover to be present across the Southern United States and the potential feedback into the third system.
02-12-2021, 02:59 PM #9
I've always winterized the boat myself.... It then gets put away in my unheated detached garage. In Central Indiana it is pretty much below freezing temps from December to February including in the garage.... my car cleaning supplies freeze solid lol..... Never had an issue with the boat knock on wood. That is the entire point of winterizing so that if it drops below freezing...nothing freezes. If you trust your dealer than nothing to worry about.
2012 Mobius LSV (Sold)
2020 Mojo
02-12-2021, 03:18 PM #10
I feel like down here that is how all the dealers do it. They winterize it and then you are good to just drop it in the water in the spring. I am wondering if I should just pop all the plugs out and open the water pump and hose connection and leave them open for the next week.
Ya it is going to pretty nasty that is for sure.2019 Makai
