Results 51 to 55 of 55
02-18-2021, 08:31 PM #51
With the 2021 F-150 you get better tow capacity and you can power your home.
https://apple.news/AcDHCqMVERKC6OA9wbeBV8w2020 SA 450 Wife calls it White Cloud. Said it makes her feel "Classy"
2017 Sanger V215sx. We call it Viagra because it's the little blue pill that gets everyone up (Sold)
02-22-2021, 03:04 PM #52
02-22-2021, 04:43 PM #53
I was doing some research last night and was blown away to see that a 2021 Ram 2500 Limited 4X4 Crew Cab with the Cummins had a max payload of 1880 pounds. I mean, that is average payload capability for new half ton. That motor must be a heavy bugger, the payloads go up about 900 pounds by going with a gas motor. I seriously don't see the point of going with the Ram 2500 over a 3500. Sure it tows more, but you have less payload capacity than a lot of half tons that pull up next to you. Both the GM HD's and the Superduty 3/4 ton models have a substantial increase in payload from their half ton offerings, but in a Ram, not so much. I know the Ram Limited is loaded up with heavy options (the lesser trims have more payload), but when I looked at Ford and GM, I made sure to look at their higher trims too and both were in the mid to high 2000's for a 3/4, which is where I would expect them to be.
2016 Starcraft Limited 1918 (sold)
2021 MB Sports B52 Alpha (coming April 2021)
2020 Toyota Tundra TRD Pro
2022 F-150 SCREW PB (ordered 12/2021...still waiting)
B-737 (Work Vehicle)
02-22-2021, 05:02 PM #54
Sounds like you chose well. This article shows the Duramax would be better at pulling up the ramp. The Ram couldn’t cut it.
https://apple.news/AtQv7iWPeSpW97yFtEvzIIA2020 SA 450 Wife calls it White Cloud. Said it makes her feel "Classy"
02-22-2021, 05:26 PM #55
8000#+curb weight, that’s 3000# more than an F150.
Sent from my iPhone using Tapatalk2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
