    Oct 2006
    Default Transmission and V-Drive oil change
    Hi,
    I am sure this has been answered somewhere before but I can not find it with the search option. Going to do a full spring service on my 04 LSV Mobius and wanted to get the low down on how to change the v-drive oil and trans oil. Engine sounds like no problem at all but the drains on the v-drive and trans are virtually un-accessible from my looking. I think I will just suck out all the fluid from each with a pump and then replace with fresh fluid. Is this what most of you are doing or something else?
    Thanks,
    Jonathan
    Mar 2004
    Martinsville,Indiana
    The main tranny has a drain on the bottom.Not really a drain but the filter.It is a pain to get to but should be checked.The fluid does go into the bilge and make quite a mess.The V drives drain isn't half as bad.Good luck.
    John
    Feb 2006
    Birmingham
    I use my evac pump and pull the fluid out of the trans and vDrive with it. It takes a while, but better than making a mess.
    15 Mondo Surf Edition
    02 LSV - Traded In
    Jul 2003
    Carson City, NV
    I use a pump and suck the fluid out of the tranny. Can't access the bottom of it. Asked my dealer and he does the same. I would bet that the vast majority pump out the fluid.
    Feb 2004
    Pump it out. A pump like this works well.
    http://www.harborfreight.com/cpi/cta...emnumber=45403
    Also measure the amount of fluid you pump out so you make sure you do no overfill the trans.
    [/url]
  1. Direct drive transmission seal change?
    By rosh in forum Service & Repair
    Last Post: 01-16-2008, 06:24 PM
  2. Transmission Fluid Change
    By mattjj23 in forum Service & Repair
    Last Post: 09-06-2006, 08:52 AM
  3. oil and transmission fluid change
    By 98outback in forum Service & Repair
    Last Post: 06-27-2006, 07:30 AM
  4. Transmission Fluid Change
    By Wesmorgan in forum Service & Repair
    Last Post: 07-25-2005, 02:30 PM
  5. Transmission Fluid Change
    By carsondoc in forum General Chat
    Last Post: 10-06-2003, 03:03 PM
