Thread: Rev10 Recone
    Feb 2011
    Euless, TX
    Default Rev10 Recone
    i'm posting for a buddy of mine who bought a used Supra last spring and one of the Rev10s cone is ripped and detached from the surround. Does Wetsounds still have a repair service to fix these. (BTW they're about 6 years old) I saw an older post that was about 6 years old of someone sending their speaker in to get reconed. If Wetsounds does not repair anymore any recommendations for a repair in the Dallas/Ft. Worth area?
    2009 LSV Liquid Force Edition
    - Gravity III - Upgraded 900lb rear locker
    - Z5 Rack
    - ACME 1847
    - Polk MM6501UM - Kicker IX500.4
    - Kicker CompVX 12" - Kicker IX1000.1
    - Pair Wetsounds Rev 10s - JL Audio HD750/1
    - RGB LEDs
    Oct 2010
    Lake Wylie NC Area
    Check with a local Wet Sounds dealer or call direct about getting you a replacement driver. Not overly expensive. Just need to make sure they have the steel basket generation replacement in stock.
    Feb 2011
    Euless, TX
    Yeah he did that already at my suggestion. I was thinking that if he went to Wetsounds dealer they would be able to send off to Wetsounds? I think that's what you have to do for JL Audio equipment? So I assumed Wetsounds would be the same? He went to Earmark in Lewisville and the guy that was there was not helpful with his request. Guy there directed him to a speaker shop in South Dallas. I'm not trying to call out Earmark as they did my Rev 10 tower setup and have treated me right.
    - Z5 Rack
    - ACME 1847
    - RGB LEDs
    Oct 2010
    Lake Wylie NC Area
    If he asked about a repair specifically, he may have gotten an accurate answer. They can be repaired. However, as long as components are in stock, the driver can be swapped in a matter of a few minutes once the new one is delivered. Just an option to look at compared to sending it off for repair.
    Henderson, NV
    If you run into dead ends might be worth a call to creative audio. They seem to be the WS outlet to peddle refurb gear and might know how to score parts.
