Results 1 to 10 of 19
    Apr 2017
    Atlanta
    Default MS-RA205 not compatible with Iphone 11 and up
    I had an issue all summer fighting my USB connection to the fusion radio not working on my new iphone. I just used bluetooth all summer or my brother in laws iphone 8, as his worked with no issues. I finally got around to contacting fusion, and their tech support stated that my head unit is no longer compatible with the newer model iphones and the only fix is to buy a new head unit (and transom remote as that wont work with a newer headunit).
    As my boat is only a few years old I am quite upset to have an obsolete head unit already so I will not be going back with fusion, does anyone have some good suggestions for a headunit and transom remote swap that would work well in the cutouts currently occupied by my fusion bricks?
    2016 Craz
    Henderson, NV
    fusion is owned by garmin and not surprised at the pace of electronics development and not wanting to spend time developing updates for older units but it's not really any different than pc's, cell phones and the likes.
    that said we had a jl audio media master head in our last boat and it was a royal pos. slow to load, lagged when swapping usb tracks and an overall poor software front. I'd stay away from that brand as you shop....
    Jan 2017
    This wouldn't be a direct fit but when I need to swap head units, this will be my next one: https://www.wetsounds.com/product/WS-MC-1
    Next model down:
    https://www.wetsounds.com/product/WS-MC-2
    Transom remote: https://www.wetsounds.com/product/ww...one-controller
    2017 Moomba Craz Surf Edition
    Jun 2020
    Utah
    I don't think the tech told you the right answer. We also have the MS-RA205 and my iPhone XS plugged in without issues. I have found the newer phones are somewhat more finicky when it comes to plug in connections, so you should check your cable and the connection between the auxiliary port and the head unit.
    Apr 2017
    Atlanta
    Quote Originally Posted by Zog View Post
    I have tried plugging in directly to the headunit in the back, no dice. My brother has an Xs and his works, 11 and up is the issue. Here is exactly what fusion told me
    "Unfortunately the MS-RA205 will not work with your newer iPhone. It does not have the proper communication Pathway to allow the audio to pass. It should look like it's going to work the song should be displaying but no audio passes. Unfortunately there's no fix to that without replacing that radio with a newer unit."
    I'm quite frustrated, my phone works fine on my buddy's 2005 malibu, so its not about tech refreshes as far as I'm concerned.
    2016 Craz
    Apr 2017
    Atlanta
    Quote Originally Posted by RC_Hinojosa View Post
    Next model down:
    This is what I have been looking at as well. Any ideas for the transom, the old unit is rectangular and this is obviously oval. Will I have a giant hole in the back if I switch to this?
    2016 Craz
    Jan 2017
    Quote Originally Posted by mcjimmy33 View Post
    Maybe you can look up the old model transom remote and see what the back looks like. Just because the front is rectangular doesn't necessarily mean the pass through is.
    Jun 2020
    Reno, NV
    I have this fear that the pace of mobile phone tech is going to outpace the boat makers, and integrated systems like the Vision system on the Supra will be useless. I mean the GoPro integration already is, what keeps phone tech from being next?
    2020 SA 450 Wife calls it White Cloud. Said it makes her feel "Classy"
    Apr 2017
    Atlanta
    good idea, I probably need to go out to the boat and look at the back of it as well.
    2016 Craz
    Apr 2017
    Atlanta
    https://pdf.crutchfieldonline.com/Im.../917NRX300.PDF
    According to this its a 2" hole, which I should be able to cover. The 4 small screw holes for the mount though would not be covered by a circular transom remote. I could fill those, wouldn't be too noticeable but definitely I would see them every time.
    2016 Craz
