Results 1 to 6 of 6
    Jul 2003
    Default Trailer Problems
    Blinkers and brake lights work fine, then when I turn on my truck lights, I end up blowing a fuse on my truck ending my head lights, internal dome, tail lights etc....Anyone ever run into this problem ? Problem just started to occur last summer.
    1999 Moomba Outback LS
    ________
    volcano vaporizer classic
    Jan 2003
    Nashville
    See my post from a few days ago. I do not blow a fuse but my trailer lights do not work right if my truck lights are on. Does your truck have daytime running lights or automatic headlights? Someone told me this might be what is causing the problem.
    Guest
    My truck has day time running lights. It's the weirdest thing, the fuse blows after about 10 minutes of usage once the lights are turned on.
    Jul 2003
    My 99 Chevy Tahoe has daytime running lights I believe. It's the wierdest thing, once I turn my lights on @ night they work for abou 10-20 minutes and then they blow a fuse.
    ________
    cheap vaporizers
    Aug 2002
    Bismarck, NorthDakota
    Just an FYI for you. I have a 2000 Chev truck and a blazer that both have daytime running lights and my trailerr lights work fine on both. I don't think that is your problem.
    Bruce Fuerstenberg
    Mar 2003
    s.e. washington state
    Check your trailering lights for a short to ground. Verify each of the lights aren't disconnected and grounding out. Use a power supply on the connector plug and verify operability. Hopefully, the fault is at the lights and not the internal wiring.
    1998 Mobius
    310 HP PCM
  1. Replies: 46
    Last Post: 01-05-2008, 12:53 AM
  2. Paint problems on Trailer
    By Wolf- in forum Service & Repair
    Last Post: 03-12-2007, 09:00 AM
  3. Problems That Will NOT Go Away
    By 05mobiusxlv in forum Service & Repair
    Last Post: 04-17-2006, 11:51 AM
  4. CD player Problems
    Last Post: 10-02-2005, 12:28 AM
  5. Trailer light problems
    By MartyC in forum General Chat
    Last Post: 07-07-2003, 05:36 PM
