Results 1 to 10 of 13
11-02-2020, 07:18 PM #1Junior Member
- Sep 2017
- Minnesota
- 7
Help: Used Oil Vacuum, now tube stuck inside
Purchased an Topsider oil extractor to do my oil changes since that is supposed to be easier than dropping the oil hose and emptying. I had pushed the hose into the dipstick until I heard it bottom on the oil pan. Sucked a good amount of oil but certainly not 5.5 qts worth. Other have said to push in further to get it to the back of the pan, did that. Was able to suck a little more but not much. Went to remove and its stuck, its like it looped itself inside and has knot. I have tried pulling fairly hard and its no go. I can push more in but it comes back to the same spot.
Any ideas?
I hope I'm not at pull the engine to get the oil pan off. What was supposed to save time could have became a real money suck.
Picture for reference.
https://www.amazon.com/America-5060T...4358626&sr=8-9
11-03-2020, 09:54 AM #2
The end of the dipstick tube can be sharp and it can cut into the tube as you pull it back and catch.
not a good situation unfortunately.
your best option is to try and twist it into as many different positions s possible and try to pull from every angle.
if it doesn't come out the dipstick tube is pressed in I would pull that out and try again before pulling the oil pan.2020 Supra SA
11-03-2020, 10:55 AM #3
Dang, this happened to me a few years ago and it was an absolute pain to get out. It took me forever twisting and bending the hose but it finally came out. Sonic is right, the end of the tube is very sharp and it just catches the hose. When mine finally came out the hose was all cut up. Just keep at it. I posted before warning people to never suck the oil out the dip stick, use the hose!
Scott
2021 Craz
1997 Sea Ray 190
11-03-2020, 11:05 AM #4
Can you get the dip-stick out - more to work with?
I know others have used the push, twist, and pull method.
https://forum.moomba.com/showthread....-dipstick-tube
Can you insert something like a clothes hangar wire/stiff wire and push it through the tube till it stops, then pull the tube while pushing the wire?
https://teamtalk.mastercraft.com/sho...=59627&t=59627
I recall reading a thread on the BU forum about a broken piece in there. They lifted the motor and dropped the pan. Not sure there is any room in there w/o lifting the motor. Getting it off would be the easy part, getting it back on right is another story.2018 Supra SL400
11-03-2020, 11:06 AM #5
I think I read your post about that. I was curious when I searched.
http://www.moomba.com/msgboard/showt...-dipstick-tube2018 Supra SL400
11-03-2020, 11:27 AM #6Junior Member
- Sep 2017
- Minnesota
- 7
Thanks for all the input guys. I will remove the dipstick and see if at that angle I can get better movement. I did push it in a bit before I left it for the night, hopefully it maybe relaxed a bit.
11-03-2020, 12:51 PM #7
11-03-2020, 01:52 PM #8
11-11-2020, 03:19 PM #9Junior Member
- Sep 2017
- Minnesota
- 7
Update and closure to this.
After removing the dipstick and an hour of twisting, rotating, etc I had not luck. I tried the coat hanger down the tube but it hit a definite end and would not straighten out the hose. Another bit of that and I gave up. I pulled as much as I could and cut. I was left with 41 inches of the tube and from what I can find the Topsider comes with a 48 inch tube. So there is 7 inches left in the oil pan in some form of knot.
I don't think it can get sucked up by the oil pump, if it was to somehow get grabbed by the spinning internals, I don't think it would damage them and would get chewed up into smaller pieces, again probably too large to get sucked through the screen of the oil pump. Perhaps they then come out during future oil changes via the drain tube.
Thats what I'm going with anyway
11-11-2020, 04:19 PM #10Senior Member
- Aug 2011
- 2,522
2006 Moomba Mobius LSV - Sold
