Results 1 to 2 of 2
10-15-2020, 03:33 PM #1Member
- Sep 2020
- 30
Ballast bag lines on Supra SA 2019
Have any of you adjusted the top lines on the rear bags so they don't keep getting crushed by the top of the compartment as they fill?
It's a Royal PITA having to drain and then fill to make sure the lines don't crimp + the elbow joint is sometimes under the lid so it's tough to shut.
Seems like a design flaw.
Also, the front bags inflate so much that the seats pop out, seems like the bags should of been designed to fit the bow better. Again poor design and maybe the reason they went with sub floor in the 2020s.
Any workarounds that you have applied would be appreciated.
Sent from my Pixel 2 XL using Tapatalk
10-15-2020, 05:06 PM #2
You might have air in your bags.
You might be overfilling bags due to your not fully draining from the previous fill.
I always had to run an extra min to drain versus fill. If you don’t fully drain, the next fill is too much.
Sent from my iPhone using TapatalkLast edited by larry_arizona; 10-15-2020 at 05:09 PM.
2021 Supra SA 400
2018 Supra SA 400 (SOLD)
Michigan
