Results 1 to 10 of 17
    Aug 2018
    Default Winterizing 2020 Supra Se
    Anything different when it comes to Winterizing the newer Supra’s? I found many videos on older boats but nothing on the newer stuff. I have always done it myself on previous Supra and Tige’s that I have owned. Thanks
    Aug 2011
    Commerce Lake, MI
    Follow the Indmar Engine manual that you were supplied with the boat.
    2017 Moomba Craz
    May 2018
    Quote Originally Posted by Stazi View Post
    THIS, things have subtly changed over the years, # of drain points and locations are slightly different for some years as well as between the 400,450 and 575, but the basic premise is largely unchanged.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Apr 2012
    Wake Forest, NC
    IMO it is much faster/easier with the closed-loop cooling than the old gm based assault engines.
    2018 Murder Max
    2008 Outback V-Bought new; sold in 2018
    May 2018
    Quote Originally Posted by z28ke View Post
    Absolutely, it’s so easy to winterize the raptors.
    2021 Supra SA 400
    Michigan
    Aug 2018
    Thanks guys, I’ll review the manual next time I’m at the lake and before I put it to bed for the season.
    Aug 2011
    Commerce Lake, MI
    I can winterize my boat in under 1 hour.
    2017 Moomba Craz
    Jul 2019
    Ohio
    Do you guys do everything yourself regarding winterization - full service (oil change, fuel filter change, etc.) and winterize? I need to look into this and learn how to do it myself, closest Supra Dealer to me is 4 hours after my regular dealer lost their Supra license.
    2016 Supra SA 400
    May 2018
    Quote Originally Posted by Jmm137 View Post
    Yes, although was never near 300 hours to consider changing fuel filter.
    Oil change, raw water impeller and drain the raw water cooling loop, make sure ballast bags tanks and pumps are drained enough etc.
    2021 Supra SA 400
    Michigan
    Jun 2020
    Reno, NV
    Do you replace the raw water impeller every winterize?
    2020 SA 450 Wife calls it White Cloud. Said it makes her feel "Classy"
    2017 Sanger V215sx. We call it Viagra because it's the little blue pill that gets everyone up (Sold)
