Results 11 to 11 of 11
09-15-2020, 12:44 PM #11
Make sure your v-belts are aligned properly and that they are correctly tightened. Also, could you possibly have the packing gland too tight at the driveshaft? Are you getting a slight drip of water when its running or do you have a dripless seal setup? If you have a dripless seal, make sure the cooling water line is flowing to the seal area. The more RPM you run, the hotter it will get. Is there any chance that something fell under you engine in the bilge are and is rubbing on the driveshaft under there?
