09-02-2020, 03:41 PM #1Junior Member
- Sep 2020
- 1
Flow 2.0 in 2020 Craz - surf tabs question
I've been doing a bunch of reading and wondering if I am getting confused by terminology/changes in the Flow system? My first question is the Wake Plate. When surfing, sounds like it should be a LOW number if not ZERO. First, I would like to confirm that and second, what does that really mean. Is zero straight out? Or all the way closest to boat (pulled in)(pushed out?)?
Second, some posts talk about setting BOTH pt/stbd tabs to certain percentage. I don't use AW or the toggle for Flow 2.0, I use the surf control in the upper left of the screen. When it is set to surf port, I can only control the center wake plate and the starboard surf plate. How does one adjust both? (surf control off?)
On a side note, is there a way to find Pitch/Roll without turning autowake on for a second?
Thanks,
GeoffLast edited by gkfrost9; 09-02-2020 at 03:43 PM.
09-02-2020, 04:46 PM #2
09-02-2020, 05:25 PM #3
You can only see pitch and roll with Autowake on. But you can quickly revert it back to cruise by flicking any ballast pump on for a second. That will kick it out of Autowake.
Sent from my iPhone using Tapatalk2017 Moomba Craz
09-02-2020, 06:33 PM #4Senior Member
- Aug 2017
- 1,382
