Results 11 to 19 of 19
08-20-2020, 12:59 PM #11
The Indmar # is 556096. I bought it from Inboard Online . https://inboardonline.com/search.php...h_query=556096
It was pricey ($200.00) , but I wanted to go with the factory original and make sure it worked. Takes 15 minutes to replace. When I received it, it had numbers on it that I crossed to a Standard Ignition Products number of LX-384. I bought this one as a spare, but have not tried it yet. I'm 99% sure it is a direct replacement though.
08-20-2020, 01:00 PM #12Junior Member
- Aug 2017
- 11
08-20-2020, 01:03 PM #13Junior Member
- Aug 2017
- 11
08-20-2020, 01:09 PM #14
You didn't mention it, but do you have a scanner or even a simple code reader? I bought a scanner and can check code faults and view live data while its running. Scanner is pricey though, ($500.00) . Code reader is about $60.00. Hate to see you keep throwing parts at it.
08-20-2020, 01:56 PM #15Junior Member
- Aug 2017
- 11
08-21-2020, 01:04 PM #16Junior Member
- Aug 2017
- 11
Just used a diy code reader (https://www.themalibucrew.com/index....er-mefi-2-3-4/) and it's showing no codes! dangit. Any other suggestions?
08-21-2020, 01:05 PM #17Junior Member
- Aug 2017
- 11
08-21-2020, 02:29 PM #18
You might look into replacing the actual distributor its self. My buddy has an 06 Supra and was having the same issue, only high rpm, normally 5-10min after surfing and he replaced everything you did and in the end it was the actual distributor failing.
[COLOR="#696969"]
08-28-2020, 10:03 PM #19Junior Member
- Jun 2020
- Colorado
- 17
What did your plugs look like when you changed them? Were ALL of them the same color? Did any of them look particularly clean?
