07-15-2020, 12:18 AM #1Junior Member
- May 2020
- 1
2002 Moomba Mobius bilge kicking on after cruising
So anytime I cruise around or pull someone and come to a stop, my bilge float will come on and kick out a steady stream for 3-5 seconds. I have checked the bottom of boat for holes or cracks and can’t find any. I will be checking the shaft seal this weekend. I have read it’s probably the seal but is that much water entering through the shaft when I run around or pull a tuner/Wakeboard likely? 250 hours and don’t think much shaft has ever been repacked. Haven’t really noticed when sitting and swimming only after a run.
07-15-2020, 03:50 PM #2Junior Member
- Jul 2020
- SLC, UT
- 6
I'd start with just tightening the packing nut. If it's still leaking, then replace the packing, but may save you a couple hours if you don't have to replace it.
07-16-2020, 06:35 PM #3
Check your hoses, water pump, block plugs, etc. I had a leaky water pump that surprisingly filled up the bilge more and more the longer I let it slide. At least it was nice warm water bath that helped cleaned it out...
07-16-2020, 10:53 PM #4
My 03 outback ls was doing the exact same thing.When running I believe the water runs to the back,when you stop it runs forward and the bilge kicks on.I had to tighten the packing nut a very small amount.
jy
07-17-2020, 01:02 PM #5Member
- Apr 2009
- Raleigh, NC
- 62
My 2005 Mobius has always done this. It's really bad when surfing. I've replaced the shaft packing a few times. I've pulled up the cover under the back seat when running and see water coming from somewhere in front of it. I just deal with it. It does slowly degrade the steering cable though. We just hit 1000 hours.
Sent from my ONEPLUS A3000 using Tapatalk05 Mobius LSV - gravity 3 ballast and wake plate
single axle trailer
DIY hot water shower installed
DIY tube inflator installed
