Thread: Amp getting noise
03-26-2007, 04:21 PM #1
Amp getting noise
Hi
I have installed an amp to power my new tower speakers and conect the psotive and negative directly from the battery becuase im not sure where to ground it on a boat, but when the boat engine is running I get noise on the speakers, and when I start the bilge pump I can hear it on the speakirs, so I wonder if you can give me some advice on where to ground the amp to eliminate the noise or to install filters or any other advise how to get it working right. My boat is a 1998 mobius.
03-26-2007, 09:51 PM #2Member
- Feb 2006
- Spruce Pine, NC
- 61
The battery is the best place to ground the amp- check your rca cables and speaker wires, sometimes interference from other current carrying wires will cause a slight "buss". Hope that helps!
03-27-2007, 04:21 AM #3
Right, make sure the speaker wires are not running with the power cables. Def try to keep them apart.
B
03-27-2007, 09:49 AM #4Senior Member
- Dec 2006
- Thomasville, GA
- 198
Don't know exactly where you are mounting the amp but try to use the shortest power, and mainly ground cable length possible. Also make sure you use a good heavy grade. Ditto on running with other power lines.
Monty
Moaning Noise?
By kylesauder in forum Service & RepairReplies: 4Last Post: 06-25-2007, 09:47 PM -
Transmission noise
By cham783 in forum Service & RepairReplies: 5Last Post: 04-10-2007, 08:38 PM -
'05 LSV Transmission Noise
By in forum Service & RepairReplies: 7Last Post: 08-15-2005, 04:28 PM -
ENGINE NOISE
By DOCDRS in forum Sales & InformationReplies: 1Last Post: 08-13-2002, 11:26 PM -
Noise Reduction
By Old fogie boarder in forum General ChatReplies: 0Last Post: 07-24-2002, 01:39 PM
