    Jun 2016
    Alberta
    Default Fat Sac Replacement Issue
    Hi, I have a 2016 Mondo that came with 750# fat sacs in the rear.
    I've purchased 1150# fat sacs that will fit (from Wakemakers).
    The issue I'm having is removing the quick connects from the old bags to install them on the new one. There is a top connector and a bottom connector, they're identical.
    All of the other plugs screw in, I'm assuming all 4 port holes are identical.
    I can't even budge the screw-in quick connects, are they just screwed in or is it possible they screwed and glued them in from the factory?
    Or am I just weak?
    Thanks.
    Apr 2013
    Knoxville TN
    Quote Originally Posted by drlynes View Post
    Or am I just weak?
    Thanks.
    If you are talking about the fittings that are glued in, you have to heat them with a hair dryer for 10-20 mins, and break the seal with you foot.
    There is a video on this:
    https://youtu.be/qpW_x9MeAQo
    2018 Supra SL400
    Aug 2011
    Commerce Lake, MI
    I recommend just buying new fitting and glueing those in as well. Use JB Weld Marine formula.
    2017 Moomba Craz
    Jun 2016
    Alberta
    Quote Originally Posted by MJHSupra View Post
    Thanks, found the video.
    Jun 2016
    Alberta
    Quote Originally Posted by Stazi View Post
    Thanks, that's what I decided to do.
