Results 1 to 3 of 3
06-28-2020, 01:31 PM #1Junior Member
- Mar 2016
- Holly Springs NC
- 3
Engine compartment divider panel rails
Hi,
I have a 2015 Moomba Mojo with Raptor 400 and upgraded rear ballast bags. I have an issue when I fill my bags about half way they put pressure somewhere causing the ballast pumps and surf system to go out. I noticed my engine compartment dividers were pushing against the engine and found that the rail along the floor that the dividers sit in is busted.
Three questions
1. Does anyone know where I can find a replacement rail?
2. Does anyone know if there is a more heavy duty rail vs the cheap plastic one that comes from factory?
3. Anyone know why this would cause my pumps and surf system to go out?
Matt
06-28-2020, 08:12 PM #2
Not sure on #3 but for 1 & 2 you can just go to Home Depot and get some aluminum C channel for the floor to replace the plastic channel the dividers sit in.
Additionally get some aluminum L taller than the C channel to keep the panels from jumping track and bowing in.
The C channel can also be used to reinforce the engine divider panels or Wakemakers sells a kit.
Sent from my Note 9 using Tapatalk2017 Moomba Craz Surf Edition
06-29-2020, 08:52 AM #3Junior Member
- Mar 2016
- Holly Springs NC
- 3
RC this is great. Exactly what I needed for the fix/upgrade.
