Results 1 to 8 of 8
    Feb 2016
    Default Smell from Engine Bay?
    Hi all - have problem I wanted to bounce of the group to see if anyone has experienced this: we have a sweet-vinegar strong smell coming from the engine bay of our 2016 Mondo. I checked for leaks - coolant or other - and found nothing. No dead animals either. Any ideas? Curious to know. Happy floating!
    May 2018
    Do you need to clean bilge?
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Apr 2013
    Knoxville TN
    Boat sit on a lift?
    2018 Supra SL400
    Feb 2016
    [QUOTE=larry_arizona;354181]Do you need to clean bilge?
    Maybe that’s the ticket. I haven’t done it, but I suppose there could be some stagnant to water in there that I cant see. Thx!
    Feb 2016
    It does sit on a lift - covered lift.
    Feb 2016
    It was the bilge! 5 gallons of soapy water, a couple laps around the lake, and everything smells good again. Thanks for the insight.
    Apr 2013
    Knoxville TN
    Quote Originally Posted by blackchrome View Post
    Pretty common when boats sit on the lift. Dawn soap works good. West Marine also sells a bio product that works, not sure if that's the one that smells like oranges.
    2018 Supra SL400
    May 2018
    Dawn works but is not lake friendly. Although they seem to use it to clean ducks in an oil spill.
    West marine and star brite bilge cleaners are lake friendlier.
    I suppose after you pull boat from lake, you can always put cleaner in bilge and let trailering action do the work, then pull plug at home.
    2021 Supra SA 400
    Michigan
