Results 1 to 10 of 16
Thread: Stainless Steel Cup Holders
03-24-2007, 11:24 PM #1
I was killing some time at a Rinker dealer before a basketball game, and saw that they had good prices ($8.39) on some stainless steel cupholders. I'd been thinking about replacing the plastic ones on my 2006 Mobius LSV but could not come to terms with the prices I was seeing ($12 and up) especially since I have to buy 11 of 'em. I don't like the fact that the plastic ones have a drain hole at the bottom as I don't want spilled pop to drain down into the carpeting - I would rather than they be contained within the cupholder. So this plus the good price convinced me to pull the trigger.
When I went to install them, I found that the SS ones were about 1/16th of an inch too small all the way around so that they would move side to side about 1/8". I took some electrical tape and wrapped it just below the rim of each cupholder about 10 times give or take, until they fit snug into the hole. The results are below. I have to say, they look a helluva a lot better than the stock plastic ones!
Al
BEFORE:
AFTER:
Al
03-25-2007, 08:17 AM #2Member
- Feb 2006
- Lynchburg Va
- 68
Looks Great !
03-25-2007, 09:03 AM #3Senior Member
- Dec 2004
- Cinci-Dayton
- 1,014
yep,
on the list for my 05 as well
03-25-2007, 10:40 AM #4Senior Member
- Dec 2005
- Ontario
- 531
Those look way better than the plastic ones
Thanks for sharing Im going to upgrade mine as well
Jay
03-26-2007, 11:03 PM #5
cup holders
Hi there, David here from central Oregon. we have a 06 LSV and I would like to change out the cup holders also. I am in portland alot for work where can I find this place ? Thanks
08 LSV, Z-5 CARGO, TANDOM AXLE CUSTOM WHEELS TRAILER.....HOME LAKE IS BILLY CHINOOK CENTRAL OREGON
03-27-2007, 12:54 AM #6
Hi David,
I got them from Fred Denham at Beaverton Marine (503-643-2987), although, when I bought them, he said is was about to raise the price to $9.99.
AlAl
03-28-2007, 12:39 AM #7Senior Member
- Jun 2006
- 194
03-28-2007, 08:24 AM #8
I see them on Wakeside.com. They have 3 5/8" and 3". AM I correct in assuming the Moomba uses the 3 5/8" ? It looks like the standard and the 3" was a later add for some limited uses?
Thanks,
bw
03-28-2007, 07:08 PM #9
bw,
Best thing to do is pull one out and measure the hole. I believe the holes were 3-3/4" diameter but I'm not positive. Also, check the reviews on the ss cup holders on wakeside - looks like they are less than the advertised 3-5/8" diameter. Personally, I'd buy just one first to make sure they fit okay.
The ones I bought were actually quite loose. I almost returned them but a roll of electrical tape took care of all 11.
Hope that helps.
AlAl
04-01-2007, 09:43 PM #10
Foudn this on Ebay... as cheap as they are I am going to try... may be too small... I'll let you know.. You may have to copy all of this link... if it does not work, search: 10 3.5" Stainless Steel Cup Holder for Poker Table Boat
Only $29.99 per 10 plus shipping...
http://cgi.ebay.com/ws/eBayISAPI.dll...ype=osi_widget
By JBMoombaMan in forum General ChatReplies: 12Last Post: 04-26-2008, 03:09 PM -
What size are the cup holders?
By pnichol080 in forum Sales & InformationReplies: 4Last Post: 02-09-2008, 02:49 AM -
Stainless Steel Bling added to 2006 LSVs
By KarMobLSV06 in forum Service & RepairReplies: 1Last Post: 01-12-2008, 06:54 PM -
By 06 OB LSV in forum General ChatReplies: 3Last Post: 05-15-2007, 11:50 AM -
Stainless steel upgrade
By pullmyfingers in forum General ChatReplies: 9Last Post: 01-20-2006, 02:34 PM
