Results 1 to 10 of 13
Thread: Screwy Ballast
06-15-2020, 11:27 AM #1
Screwy Ballast
Took the boat out yesterday for the first time this season, started filling the right side ballast bag up, once filled i switched to the left side. After a while I noticed the right side starting to bilge looked under the locker and it the right side bag looked like it was going to burst. Looked in the left locker and the bag was empty and dry.
Determined that the left bag was somehow filling up the right bag. I couldn't get the left bag to get any water.
Any ideas?
08 mobius lsv2008 Moomba Mobius LSV.
325 ASSAULT
06-15-2020, 11:30 AM #2
Sprinkler valves are sticking. Just replace them. They are cheap enough. Better option than regular sprinkler valves is to replace them with these for better flow:
Motorized Ball Valve- 1/2" Stainless Steel Electrical Ball Valve with Full Port, 9-24V AC/DC and 3 Wire Setup by U.S. Solid https://www.amazon.com/dp/B06XD3W8QD..._yq55EbRYNRWFY
Sent from my iPhone using Tapatalk2017 Moomba Craz
06-15-2020, 12:27 PM #3
06-15-2020, 12:30 PM #4Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
I replaced my original Orbit valves with Irritrol 700B valves. No issues after many seasons of use.
https://www.amazon.com/Irritrol-700B...2238213&sr=8-42005 Mobius LSV
325 EFI
08-31-2020, 01:58 PM #5Junior Member
- Aug 2020
- 4
So are these a direct replacement for the sprinkler valves on the same manifold? Just got our first v-drive (02 Outback LSV) and would like to fix the issue of the bags filling up at speed. Thanks!
2002 Outback LSV
(First Inboard)
1992 Larson I/O - sold
08-31-2020, 02:32 PM #6
08-31-2020, 03:02 PM #7
If you go to the electric balls valves instead of the diaphragm style sprinkler valves they will fill about 40% faster.
09-20-2020, 10:11 AM #8Junior Member
- Sep 2020
- Kansas
- 3
Hey all, I just bought a 2006 Mobius XLV and both my rear bags are filling when at cruising speed with the pumps off. Would the sprinkler valves be causing this issue as well? Thanks for your help.
09-20-2020, 11:32 AM #9
Yes, common issue with failing sprinkler valves.
Sent from my iPad using Tapatalk2017 Moomba Craz
09-20-2020, 03:23 PM #10Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
