    Default Puppy pump impeller
    I have a 18 craz, I found my 3 pumps, the back two seem straight forward how do you change the impeller on the middle front pump, its by my T handle drain with little access
    Gotta pull your Center floor panel out. Then just take the hoses off and screws out that hold the pump and flip it for access
    Quote Originally Posted by Craz16 View Post
    Is this a difficult task, have any insight on taking the floor out
    I believe there are 5 screws holding the floor panel down. The hardest part is popping it out so you can lift it. I suggest opening the transmission cover and pushing up on it through there to get a hand or something underneath an edge. After that just lift the panel out. As far as I remember it’s not that heavy, just a little awkward
