    Jun 2020
    Default Wet sounds not playing vocals, also constant buzz
    Hey guys,
    Complete new guy to marine electrical- well most electrical for that matter. I just recently picked up a new to me Moomba that came with wet sounds on the tower, the audio generally sounds great, but I noticed the other day the tower speakers don’t have vocals only instruments through them, and when they’re on they continuously buzz. I would imagine this has something to do with the wiring. What do you guys think? I’ve attached photos of the wiring for the amp/speakers/sub. Any help would be much appreciated. I can also post more photos if need be.
    Thanks!D5E58E4F-1C56-4159-96AD-BD76C9935B00.jpgE640A0D5-063F-49F6-917F-4A3BCD3176D5.jpg
    The photo with my hand shows the wires coming down through the tower to the amp and their connection points.
    Oct 2010
    Lake Wylie NC Area
    Blown tweeter or cross-over can result in just the mid-bass working. Amp or head unit settings could limit the audio signal to the speaker. Defective amp.
    Jun 2020
    Okay, is there a good way to test this to be sure?
    Oct 2010
    Lake Wylie NC Area
    If the amp or head unit low-pass setting is enabled, you would likely not get any vocals. Would could rewire an in-boat speaker to the tower amp and see if it plays normal or the same no vocals. If you have multi-meter, you can ohm out the pods. A blown tweeter or cross-over will throw off its 4 ohm nominal impedance.
