Results 11 to 14 of 14
Thread: HELP wanted with 2020 Craz wave
06-04-2020, 12:26 PM #11Junior Member
- Feb 2020
- Indiana
- 4
Here is our 2019 Craz (stock ballast) setup that works every time:
Autowake OFF
300lbs of lead evenly distributed evenly under rear bags
100lbs of lead evenly distributed evenly in the bow
Fill all ballast 100%
Wakeplate at 0-10
Leave surf plates at factory settings
Speed = 10.8-11.2
Tip 1: Make sure your bags are actually full, and burp any air out of the bags. We do this once per weekend. The tanks are on timers and will some times lie to you. Our front tanks are rarely even close to full when the pump shuts off.
Tip 2: Get a good board. The best thing I ever did as a bigger rider on a small-ish wave was get a Slingshot Coaster. You will not regret it. Use all 3 fins at first, then start removing them for more fun as you get comfortable.
Tip 3: Autowake: just don't use it until you get your wave dialed in without it. We never use at this point, and always have a great wave.
06-09-2020, 01:51 AM #12
I changed my pitch and roll settings, does anyone remember the default numbers for a Craz? Also everyone up to this point was surfing regular and a new person is goofy. I have not really messed with that side for making a wave. Does anyone have some rough, pitch, roll, speed and surf tab settings?
2018 Craz, 3000lbs stock ballast, ENZOs, 500lb Lead Ballast, Still chasing the best wave!
06-09-2020, 09:06 AM #13
06-21-2020, 10:24 AM #14
