Results 1 to 10 of 14
    Default HELP wanted with 2020 Craz wave
    So picked up the new boat and having a hard time dialing in the wave. I did upgrade the factory rear bags to the 1190 wake makers bags. have tried tabs at 65-80 percent wp at 0 and around 10.8-11.2 mph. front bag usually at 100 percent. surf side 100 and other side 60-70... Im a bigger guy 250lbs just seeing if anyone can give me any info that might help of that I am doing wrong. There is usually 3-4 people in the boat. Again I appreciate any help or ideas. thanks in advance
    May 2018
    What are your pitch and roll numbers?
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    I will admit that I forgot to get yesterday when I was out.
    Jan 2017
    Big guy here
    Speed is good....Fill front and surfside 100%, non-surf 85%.
    (Ideally get some lead so you can fill 100% all the way around)
    Surf tab around 85%, wakeplate 0-10%
    Sent from my SM-N960U using Tapatalk
    2017 Moomba Craz Surf Edition
    May 2018
    Does your Autowake surf presets not give a good wave?
    2021 Supra SA 400
    Michigan
    Aug 2011
    Commerce Lake, MI
    Fill all bags to 100%, then engage autowake. Move passengers to surf side and watch Autowake to see where it’s wanting to take water out. Move people to the opposite location.
    In my Craz I have upgraded bags and 500lb of lead at mid/rear location on both sides.
    At 250lbs you can still surf, but really you need more ballast. I’d also recommend adding a 400 or 700lb bag on the surf side towards the rear. I’m 210, so I know the need for extra ballast.
    2017 Moomba Craz
    Quote Originally Posted by RC_Hinojosa View Post
    Big guy here
    NICE Wave! thanks for the reply I will try that this weekend
    no its short and decent height not much push
    May 2018
    Quote Originally Posted by miltonbradley View Post
    Push seems to be greatly increased with more ballast and displacement.
    Key is to find your pitch and roll that gives you a good shape and clean wave, use minimal wake plate (I only tweak wakeplate slightly if I lose my pitch mid session), once you have that figured out, add lead midship to increase push with displacement.
    2021 Supra SA 400
    Michigan
