Results 61 to 70 of 93
Thread: Ragboy’s surf setup tutorial
06-11-2020, 11:01 PM #61
06-15-2020, 12:52 PM #62Member
- May 2017
- Brooklyn & Vineyard Lake, MI
- 58
Is the clinometer app easy to use / set-up?
2008 Mobius LSV
1100's each rear
570 ski locker
750 IBS
Plus bags 625 and lead 650
Reversible pumps-3
ACME 2937 prop
Fresh Air Exhaust
Swell shaper
06-15-2020, 10:22 PM #63
06-15-2020, 11:01 PM #64Member
- May 2017
- 58
great, thanks.
2008 Mobius LSV
1100's each rear
570 ski locker
750 IBS
Reversible pumps-3
ACME 2937 prop
Fresh Air Exhaust
Swell shaper
06-19-2020, 04:24 PM #65
We finally got some good weather and I got my boat in the water. I went out and played with Autowake, both regular (what I surf) and goofy.
It didn't matter too much what I did, the goofy wave was spectacular. It took a lot more fiddling to get close with the regular wave.
I filled all ballast to 100%, just me in the boat, then turned on Autowake with pitch set to 9.5, roll to -2.5 (too much) and Amplitude to 100. It dumped a bunch from the starboard and center ballast to try to achieve numbers. It was able to get static pitch and roll but not amplitude. I reduced the roll to -1.5 and played with Swell tabs a bit. I got my best wave on the regular side at 70. Still unable to achieve amplitude.
Because it was dumping from the front and right, I tried moving some lead. I took 100 out of the bow and moved it under the left rear seat (now 250 under that seat, just 50 in the bow).
Finally Autowake pretty much kept the ballast full, achieved pitch, roll and amplitude, and the wave was damned good.
Switched over to a goofy preset to see if it could achieve numbers with the lead where it was, and it did.
So hopefully when I have people on board, Autowake will just tell me if I need to move a person or 2 to achieve numbers and I won't have to lose water or move lead.
At no time did I feel having the wakeplate above 25 helped, contrary to Wake9's video.2019 Supra SL450
06-19-2020, 04:30 PM #66
I don’t think you can force amplitude, amplitude is simply how much potential you have with what the draft sensor says is on the boat.
To get max amplitude, you need more lead, crew or both,
Full ballast and only you is nowhere near max amplitude.
2018 Supra SA 400 (SOLD)
Michigan
06-19-2020, 04:40 PM #67
06-19-2020, 05:15 PM #68
Ragboys comment of using half wakeplate is erroneous. Sorry but it is.
The wakeplate lift the ass end out of the water which is counterproductive to adding all the ballast into you boat in the first place. I have NEVER seen the need for anything more than 10-15% of wakeplate deployment, and tha.t was only when I had a full boat. 99.9% of the time I run with it ALL the way up.
Sent from my iPad using Tapatalk2017 Moomba Craz
06-19-2020, 05:22 PM #69
06-19-2020, 05:34 PM #70
