Page 1 of 10 123 ... LastLast
Results 1 to 10 of 93
    Oct 2016
    Tims Ford Lake TN
    Default Ragboy’s surf setup tutorial
    If this was already posted, sorry. Thought everyone would enjoy as I saw it on Wakeworld.
    https://youtu.be/fRX6v9QpycI
    2016 Mojo Surf
    Raptor 400
    FAE
    Commerce Lake, MI
    I agree with most of it except the 50% wakeplate comment. That’s far too much. It lift the stern out of the water at that much deployment.
    2017 Moomba Craz
    Oct 2016
    Tims Ford Lake TN
    I agree Stazi. Maybe if you are slammed with weight but I haven’t reached that point on the Mojo.
    2016 Mojo Surf
    Raptor 400
    FAE
    Commerce Lake, MI
    Quote Originally Posted by BigOrange View Post
    2017 Moomba Craz
    May 2018
    ANACORTES, WA
    Agreed, I run mine around 25-15 depending on people to maintain the pitch I want. I also used the clinometer app he talks about. I don't use auto wake but like to keep track of my pitch and roll and this app does a great job at it.
    2018 Craz, 3000lbs stock ballast, ENZOs, 500lb Lead Ballast, Still chasing the best wave!
    May 2020
    Nashville
    When you say slammed, how exactly are you quantifying that? Rub rail at level of water, etc?
    2018 Moomba MOJO
    4100lbs. ENZO's, Center Tank, IBS
    780lbs. Lead Wake
    Raptor 400
    Surf Prop: OJ 945
    2019 Ford F150 FX4
    5.0L V8
    Aug 2017
    I was thinking the same thing when I watched it. You'd have to lighten the bow or add a ton of weight to the rear to get 9.5 with the wakeplate at 50.
    That's where I run it for my daughter and my buddy's daughter to squash the wave down and make it more "skimmy."
    Sent from my SM-G950U using Tapatalk
    2019 Supra SL450
    Apr 2013
    Knoxville TN
    I like the Barbie boat.
    2018 Supra SL400
    Oct 2016
    Tims Ford Lake TN
    I wouldn't be comfortable running with the rub-rail toward the water line. Right now I have 1100 rear bags, the 750+500 center and IBS, and 600 lbs of lead rear and mid-ship. I enjoy wakeboarding more than surf, so I'm not a pro at dialing my wave yet. But, at those weights, I still need to run the wakeplate at 0 to 10% in order to not loose push.
    2016 Mojo Surf
    Raptor 400
    FAE
    Aug 2017
    With how deep these boats are now, I don't think you'd be able to add enough weight to get the rub rail to water level when stationary. Probably in an LSV, but not in the newer designs.
    2019 Supra SL450
