Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 55
  1. #41
    Jul 2019
    I ordered the 8k. It shipped today. I will let y'all know next week how it turns out
    2019' Moomba Max
  2. #42
    May 2018
    Waynesville, Ohio
    We were out later last night. Here is a better pic. It was pretty dark out in this one.
    2018 Moomba Craz
    6.2L Raptor 400
    6 Pump Ballast, Autowake 2.0, Flow 2.0 Surf System
    OJ 15x13 Wake Prop
    Digital Cruise Pro 3 (paddle wheel)
    Wetsounds Rev 10's
    2005 Supra Launch 22SSV - Sold
  3. #43
    Ok, now that does look quite a bit brighter then the 10W that I have.
    Mike
    - FAE
    - DIY suckgate
  4. #44
    May 2018
    Waynesville, Ohio
    Quote Originally Posted by DNIXD99 View Post
    Yes, let us know. It didn’t look like that one would clear my wakeplate or I would have tried it. Would love to see a pic of the install to see if it would clear.
    2018 Moomba Craz
    6.2L Raptor 400
    OJ 15x13 Wake Prop
    Wetsounds Rev 10's
  5. #45
    Finally got a pic of my 10W plug light - as you can see there isn’t much light coming from under the platform.....20W is definitely the way to go if you are thinking about this upgrade.
    Mike
    - FAE
    - DIY suckgate
  6. #46
    Feb 2017
    Colorado
    I had the 10, just got the 20 in. Will get a side by side pic to compare.
  7. #47
    Quote Originally Posted by jph3 View Post
    Do you think you will be able to just swap out the light and the short section to the disconnect or are you planning to replace the whole wire?
    Mike
    - FAE
    - DIY suckgate
  8. #48
    Feb 2017
    Colorado
    Drivers look the same, wiring is the same otherwise so my plan is to swap it at the plug.
  9. #49
    Nov 2019
    The stern plug on my Helix is above the center plate it would seem the light would just shine on the plate and not light up the water. Does the light only light up the water if plate is at 100%?
  10. #50
    Feb 2017
    Colorado
    Default Under water lights
    This is the 10w when docked. Not sure what the plate level is...
