Results 1 to 3 of 3
06-28-2003, 09:16 PM #1Junior Member
- Jun 2003
- Houston
- 8
How Is Oil Filter Accessed - Kamberra?
I recommend anyone ordering a "new" Moomba opt for the "remote location for the Oil Filter" option. Its got to be in a better location than the "standard location".
Does anyone know how to get to the Oil Filter? And change it without going to a Moomba dealer? On my Kamberra, its under the starboard side of the engine pretty much inaccessable - unless you're a double jointed contortionist.
Any ideas would be appreciated.RickHouston
06-28-2003, 11:50 PM #2Brian Raymond Guest
Filter change
It's not that bad, just time consuming. Remove the vinyl walk-thru panel, remove the water intake hose on the intakeside of the transmission cooler, remove the trans. cooler mounting bolt(11/16) I think, and lay it to the side. The filter should be fairly accessable, loosen with a filter wrench, use a discarded bread bag and slide under the filter, loosen by hand, and let the filter fall into the bag, hold there for several seconds to catch any dripping oil, (previously, lay several rags in bilge under filter). You should then be able to manipulate the filter in bag out of the boat with little mess. Repeat above in reverse order. DO NOT forget to put the water intake hose back on the trans. cooler, it makes for a very expensive oil change.Brian Raymond
06-30-2003, 08:02 AM #3Senior Member
- Aug 2002
- Bismarck, NorthDakota
- 579
Brian,
I have been changing oil on all of my vehicals for many years.
Your bread bag idea is the best idea I have heard in many years, I will use it for every oil change from here on out, Thanks for the GREAT idea!Bruce Fuerstenberg
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting...holy shit!...what a ride!
Similar Threads
Kamberra w/ our tow rig
By tygger6069 in forum Pride & JoyReplies: 9Last Post: 01-17-2013, 02:42 PM -
Kamberra
By Matt W in forum General ChatReplies: 2Last Post: 08-06-2004, 08:52 AM -
kamberra
By drewskiren in forum General ChatReplies: 1Last Post: 04-04-2004, 11:13 PM -
Kamberra
By Hurndaddy in forum General ChatReplies: 6Last Post: 02-27-2004, 11:32 PM -
New Kamberra
By newbieonthelake in forum Boat OwnersReplies: 7Last Post: 02-13-2003, 12:22 AM
