Results 1 to 3 of 3
    Jun 2003
    Houston
    Default How Is Oil Filter Accessed - Kamberra?
    I recommend anyone ordering a "new" Moomba opt for the "remote location for the Oil Filter" option. Its got to be in a better location than the "standard location".
    Does anyone know how to get to the Oil Filter? And change it without going to a Moomba dealer? On my Kamberra, its under the starboard side of the engine pretty much inaccessable - unless you're a double jointed contortionist.
    Any ideas would be appreciated.
    RickHouston
    Aug 2002
    Maryville, Tn.
    Default Filter change
    It's not that bad, just time consuming. Remove the vinyl walk-thru panel, remove the water intake hose on the intakeside of the transmission cooler, remove the trans. cooler mounting bolt(11/16) I think, and lay it to the side. The filter should be fairly accessable, loosen with a filter wrench, use a discarded bread bag and slide under the filter, loosen by hand, and let the filter fall into the bag, hold there for several seconds to catch any dripping oil, (previously, lay several rags in bilge under filter). You should then be able to manipulate the filter in bag out of the boat with little mess. Repeat above in reverse order. DO NOT forget to put the water intake hose back on the trans. cooler, it makes for a very expensive oil change.Brian Raymond
    Aug 2002
    Bismarck, NorthDakota
    Brian,
    I have been changing oil on all of my vehicals for many years.
    Your bread bag idea is the best idea I have heard in many years, I will use it for every oil change from here on out, Thanks for the GREAT idea!
    Bruce Fuerstenberg
  1. Kamberra w/ our tow rig
    By tygger6069 in forum Pride & Joy
    Last Post: 01-17-2013, 01:42 PM
  2. Kamberra
    By Matt W in forum General Chat
    Last Post: 08-06-2004, 08:52 AM
  3. kamberra
    By drewskiren in forum General Chat
    Last Post: 04-04-2004, 11:13 PM
  4. Kamberra
    By Hurndaddy in forum General Chat
    Last Post: 02-27-2004, 10:32 PM
  5. New Kamberra
    By newbieonthelake in forum Boat Owners
    Last Post: 02-12-2003, 11:22 PM
