Results 1 to 10 of 11
Thread: Surf wave help
    Nov 2019
    Default Surf wave help
    I just surfed behind my 19 helix for the first time , wave needs more push I was struggling to keep momentum . Thinking I need more ballast or open to other suggestions. I’m not a big dude, 5’10’/ 170lbs
    Aug 2011
    Commerce Lake, MI
    How much ballast do you have?
    What size bags and where?
    2017 Moomba Craz
    Nov 2019
    I have the integrated bow sack option and the two stock ones in the rear but no extra or after market added yet.
    Aug 2011
    Commerce Lake, MI
    How big are your rear stock bags? My guess is that they’re tiny.
    2017 Moomba Craz
    Henderson, NV
    replace rears with 1100's. if you normally run with a large crew that should help. if crew is smaller, add another 500lbs in lead midship.
    Nov 2019
    Not sure of the size of the rears to be honest , they are the ones that came stock. Not sure if I should be filling front bags 100%? And do I want to fill both rears 100% or more weight on surf side ?
    Nov 2019
    Ok so the front integrated bag is 400, the center tank is 400 and the rears are 650 each. I’m thinking I want to upgrade the rears.
    Aug 2011
    Commerce Lake, MI
    Yeah those tears are what I had stock too. They are tiny.
    You need 1100’s minimum in the back on both sides.
    Plan on buying new connectors for the bags too as it’s almost impossible trying to remove the ones in there as they are glued in. Also suggest you glue the new ones in too.
    2017 Moomba Craz
    Nov 2019
    Ok I’m on it, thanks so much for the input.
    Nov 2019
    Wakemakers has an upgrade kit For $699 that is designed to work with the boats ballast hookup , the bags are 1040lbs each. Would like to avoid having to manually fill bags obviously.
