Results 1 to 3 of 3
05-08-2020, 11:17 AM #1Junior Member
- Feb 2020
- 2
Went to de-winterize and no spark Indmar 340
Boat won’t start. 2005 Indmar 340 (catless).
Turns over fine, no spark.
I’ve hard wired the kill switch to eliminate that.
My 4 wires at the coil when key at ON position.
1: is getting 12v
2:10.8v
3: is saftey switxh
4: nothing
I just installed this coil at the end of last season, worked fine a few times before winterization.
Plugs, rotor, cap all new last season as well.
I’ve checked all grounds.
I’ve ordered another ignition coil, hoping my new one is just faulty.
Any other ideas?
05-08-2020, 12:00 PM #2
All breakers in good standing?
I know you said you have a no spark condition, but do you hear the fuel pump priming? That would tell you if you have power back there.
What is the 10.8v terminal? Wonder why you're not getting closer to 12v?
Sent from my SM-G955U using Tapatalk2008 OBV
325 EFI with closed cooling
Gravity III with 750's in the rear, 400 stock floor, 750 IBS
Servo valve ballast upgrade
Wetsounds Rev10
JL Amps, WS420BT
2000 Outback LS <-- Sold!!!
310 Carb Direct Drive
800# Rear Locker
750# IBS (should have kept this for the OBV)
Dual Batteries with 2 Bank Charger System
Kenwood Head with Remotes
Too many hours restoring exterior from prior negligence to count!
05-08-2020, 12:20 PM #3Junior Member
- Feb 2020
- 2
Yah I hear the fuel pump whine and pressurize.
The 10.8 is also my concern. Really hoping it’s not the ECU. I’m hoping I can find my Clymer shop manual to check the wiring diagram.
