Results 1 to 6 of 6
Thread: What did I break?
05-04-2020, 11:14 AM #1
What did I break?
Started my first day on the water yesterday with two dead batteries. My trickle charger wouldn't work for some reason so I brought my jumper pack thinking I'd be safe. I wasn't. Fortunately there were a couple real nice guys at the ramp willing to lend a hand. One had a spare battery and was willing to let me use it to start my Craz. I swapped it in, boat started right up and I went to swap back my battery. Here's where it went wrong. I got the cables back on the terminals and was tightening them down with my ratchet. Like an idiot, in a hurry and hoping to get on the water, I swung the ratchet around while tightening the - terminal and hit the + terminal. The boat shut off and everything died. I repeated the battery swap process and the boat started up again without issue.
I went out on the water to realize later that the radio had no power and my toggle switches had no power. They were working previously. My jumper pack had enough power to turn them on, but not enough amps to crank the boat over. The touch screen is working though, so I'm assuming when I shorted out the battery I did something to the other equipment? Am I lucky enough to have just blown some fuzes? Or have I done something worse here?
I'm not much of a mechanic so I appreciate any insight. Thanks'19 Moomba Craz
'17 Heyday WT-1SC - Traded
05-04-2020, 11:38 AM #2
Check your circuit breakers to see if some are tripped. Mine are located under my dash, not sure where yours are
Sent from my SM-G955U using Tapatalk2008 OBV
325 EFI with closed cooling
Gravity III with 750's in the rear, 400 stock floor, 750 IBS
Servo valve ballast upgrade
Wetsounds Rev10
JL Amps, WS420BT
2000 Outback LS <-- Sold!!!
310 Carb Direct Drive
800# Rear Locker
750# IBS (should have kept this for the OBV)
Dual Batteries with 2 Bank Charger System
Kenwood Head with Remotes
Too many hours restoring exterior from prior negligence to count!
05-04-2020, 11:45 AM #3Senior Member
- Mar 2017
- Middle TN
- 232
On mine there is a breaker beside my battery on/off switch under the observer's seat that I believe leads to the dash electronics.
'18 mojo
05-04-2020, 05:32 PM #4
05-04-2020, 07:30 PM #5Senior Member
- Mar 2017
- Middle TN
- 232
05-04-2020, 09:22 PM #6
