Results 1 to 3 of 3
    Jul 2019
    Default HELP No Power to 1 Front Ballast Pump
    One of my front ballast pumps doesnt have power. I switched the connections, and both pumps are definitely working. Ive been working on the boat all weekend. From under the dash, all through the bow, to the amplifier. I added an amp, subs, and plumbed a bow bag. Im sure I knocked something loose
    somewhere, or blew an inline fuse, if there is one.. What I need to know is how the wires run between the toggle switch and front pumps. Is there an inline fuse, ect.? Im going back today with a voltmeter, ect., and Im sure Ill find the problem, but it would be a lot easier if I knew how its laid out between the toggle switch and the pumps. Basically fill in the dotted lines on my crappy drawing.
    2019' Moomba Max
    Jul 2019
    2019' Moomba Max
    Feb 2018
    Boating on Lake Martin, AL
    Yup was going to say there are 3 separate ballast relay modules that control the system. I had one of my modules go bad (port side module had a melt or short inside) last year. Had it replaced under warranty. Glad you got it fixed.
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
