    Jun 2019
    Dallas, Texas
    Default Indmar 340 Engine Block Plugs
    Looking for some advice... I winterized my 2009 Moomba last winter with some help from a DIY video on this thread. When I drained the engine by removing the engine plugs, I noticed that they were corroded and the holes were rusted. I bought new plugs but still having trouble getting them in. How do I get rid of the corrosion in the hole? I was successful with one plug I think. How far does it need to be screwed in? Not sure this is far enough. See my pic for example.
    M17
    2009 Moomba Mobius XLV
    Jul 2002
    London Ontario Canada
    Re-tap the hole. I always remove the plugs then put them back in after drainage and poking the holes to release and accumulated rust deposits
    09 21v LAUNCH
    99 Outback LS. Sold
    Doug
    Sep 2005
    Claytor Lake, VA
    Use a 1/4" NPT tap and a little WD-40 to clean out the threads and then replace the original plugs with brass ones. Same for the v-drive drains. I just did mine this weekend.
    2005 Mobius LSV
    325 EFI
    Jun 2019
    Dallas, Texas
    Quote Originally Posted by VA LSV View Post
    Thanks for the help here. Cleaned out the threads with the Tap and the brass plugs went in just fine. I was finally able to get on the water. Water still a little cold for my liking but should warm up this week.
    M17
