Results 1 to 10 of 12
Thread: DIY Surf Deck
    Salt Lake City, Utah
    Default DIY Surf Deck
    Ive been wanting to do this for a while and since work has shut down i decided to get started a few weeks ago. I basically followed aerolland's design from this thread.
    https://forum.moomba.com/showthread....f-Platform-DIY
    I'm not done yet but this is where i am at so far:
    First picture is the shape and size compared to the oem swim deck.
    2nd picture is after the first coat of epoxy mixed with a black die. I thought this would be better than using clear epoxy and painting it later.
    3rd picture is after sanding down the first coat starting with 80grit down to 220grit. There was a lot of dripping that happened over the edges (you can see it in the picture) so a fair amount of sanding was needed. I kind of like the dull "matte" finish look.
    4th picture is after the 2nd coat of epoxy. I did a much better job on the 2nd coat but will still sand down to probably something like a 2000grit and then polish to get the high gloss look back so it matches the boat.
    I'll update as i get more done.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Commerce Lake, MI
    Looks great!
    2017 Moomba Craz
    Looks great. What products did you use for your epoxy
    Scott
    2021 Craz
    1997 Sea Ray 190
    Jan 2019
    Lake Tahoe - 6200 feet elevation
    I’ve worked with similar stuff, but only clear. What did you use to add the black in?
    Just a little trick I also learned if you use a heat gun or really lightly use a torch it sucks the bubbles out quicker. (Yours looks awesome, just curious if you heated it?)
    this is the dye i used. only need a few drops mixed in and it worked awesome.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    Yea i did use both a torch and a heat gun to get the bubbles out. I watched a lot of videos on how to do it otherwise i ever would have guessed to use heat. Thanks, it turned out pretty good, not perfect but pretty good.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Sep 2016
    Horseheads, NY
    How much epoxy did you end up using?
    -Scott
    2000 Moomba Mobius V
    May 2013
    I did my bathroom counter with a clear epoxy with metallic flake. It turned out awesome (I did clear over the old formica that was painted black).
    The torching was fun!!!!
    I like how yours turned out. looks awesome. Makes me want to epoxy something on my boat!!! Especially since I have a ton of silver flake left over! LOL.
    www.TraysonsToybox.com
