Thread: 06' Outback drive shaft size
03-18-2007, 12:12 AM #1Member
- May 2006
- Pendleton, Oregon
- 48
I want to order a dripless shaft seal for my 06' Outback. Does anyone know what the shaft size is or which one I need to order?
03-18-2007, 07:29 PM #2
Your shaft size 1". You can get them from your Skiers Choice dealer, part number 107007, or you can order from SkiDim.com, item #21705. Both will be around $150.
03-20-2007, 06:13 PM #3Member
- Jun 2003
- Louisville
- 68
Which seal are you planning on installing? I ordered the OJ style and after receiving it I'm having second thoughts about installing it. The seal that makes contact with the shaft is a rigid graphite that really looks like it do some scoring to the shaft on break in and if it ever gets out of alignment. Jon, do you know if the #21705 is the style that is going on the '07s?
Although it costs $50 more, the pss shaft seals look like a better design because the rotating seal does not make contact with the shaft itself. It looks like it would eliminate any wear or damage that could happen to the shaft.
03-20-2007, 10:28 PM #4Member
- May 2006
- Pendleton, Oregon
- 48
I ordered the PSS shaft seal. I should be getting it soon. I thought the same thing when I compared the two, the PSS looks a lot better. If anyone has any tips on installing this please let me know. Thank you.
Drive Shaft
By VA LSV in forum Service & RepairReplies: 6Last Post: 05-06-2008, 08:31 AM -
Bent Drive Shaft
By kmcg in forum Service & RepairReplies: 4Last Post: 09-05-2007, 08:28 AM -
Shaft packing - what size?
By NH Moomba in forum Service & RepairReplies: 5Last Post: 04-26-2006, 07:35 PM -
Shaft Size
By bryanen in forum Service & RepairReplies: 4Last Post: 10-01-2004, 09:43 AM -
Installing a new drive shaft
By jon_n_andrea in forum Service & RepairReplies: 5Last Post: 03-18-2004, 11:58 PM
