    Default 18 crazy battery
    boat is 20 months old i looked thru the manual and couldn't find the answer is the battery under warranty if winterized properly and now needs to be replaced
    Good chance not, but what leads you to believe it needs to be replaced. Does the boat have an on-board charger that was in use during the layup? Its normal for a wet cell battery to have some parasitic draw down over time, but this does not make it bad and in need of replacement.
    Apr 2013
    Knoxville TN
    Quote Originally Posted by Sickpainter View Post
    It's a dealer installed item when they take delivery, not SC. Did you buy from a dealer or private?
    Your dealer may have some wiggle room depending on who they are buying batteries from and that company's return policy.
    2018 Supra SL400
    May 2018
    Very odd for batteries to go bad within 20 months as long as you keep them on a battery tender.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    I dropped it with the dealer for the dewinterization and had them test the batteries while they had it as I always do, they said the one wouldn't hold a charge and needed replaced, just seemed odd to me as its so new
    If your storaging the boat you need to keep the battery tender plugged in. Otherwise you'll be buying new batteries every year. .
    2006 Moomba Mobius LSV - Sold
    May 2018
    Did you keep your battery tender plugged in?
    2021 Supra SA 400
    Michigan
    Yea i have the dual battery with tender set up
    Apr 2013
    Knoxville TN
    I would buy 2 new batteries. No use having an old and new as 1 bank.
    2018 Supra SL400
    May 2018
    You should at least get a prorated warranty on the battery that failed, most batteries are prorated for at least 36months from the battery manufacturer.
    But batteries are relatively cheap.
    2021 Supra SA 400
    Michigan
