    Mar 2020
    Denton, TX
    Default Boat cover holding water
    Any pointers on what I might be doing wrong with my cover set up? Cover keeps holding water on either side right behind the tower. Have both poles under. I’ve adjusted it as tight as I can, with the front as high as it will crank.
    --Justin
    2019 Moomba Makai
    Dec 2018
    Tarp. I have a Max, no poles, but last spring it would do the same. From my last boat experience, you need to get that water off asap or the material will stretch, permanently. No problems with the tarp through winter. Doesn't answer your question but may provide a quick fix.
    19 Max
    Fully Exiled
    Mar 2020
    Denton, TX
    Quote Originally Posted by Kirby View Post
    Yea I have been bailing water with buckets all weekend. Looks like I’m going to have to find covered storage for it ASAP.
    I appreciate the input!
    --Justin
    2019 Moomba Makai
    Apr 2013
    Knoxville TN
    Not sure about this model, but someone was posting about using those kids inflatable bouncy-balls to support under the tarp. Prevented the tarp from sagging any lower, water would run off.
    2018 Supra SL400
    Jun 2018
    Lay Lake, AL
    I had that problem, and i found the Hangtyte works great. Easy to tighten up and take down
    https://monstertower.com/hangtyte.ht...QaAsubEALw_wcB
    Aug 2015
    Mn
    Quote Originally Posted by Pnut80 View Post
    That's what my Mojo's cover came with, exactly as pictured. It works well.
    2020 Supra SL 400
    2015 Moomba Mojo(Sold)
    2018 Yamaha Waverunner(Just to fool around)
    2018 F150 Lariat
    sport edition, 3.5lt ecoboost
    Feb 2018
    Boating on Lake Martin, AL
    My Max cover also has Hangtyte. I assumed the Makaii also came with it. We have a pole for the bow but use Hangtyte for the rear.
    2019 Moomba Max "MOOMBAE"
    2016 Yamaha AR192 - sold
    Mar 2020
    Denton, TX
    Quote Originally Posted by haknslash View Post
    Yes, the makai came with it. I just didn’t have it cinched up tight enough. Was worried that if I got it too tight it would rip. But I fixed it I think, we are about to get plenty of rain to test it out.
    --Justin
    2019 Moomba Makai
    Feb 2018
    I keep mine very tight when I stored outdoors last year. I was hesitant at first because it was my first time having the hangtyte system but yea you want that thing pretty tight so it can shed water quickly and not allow pooling. I also had to learn you need that bow pole extended quite a bit and also cinch the cover tight. This year we got an enclosed storage unit being built and I’ll be glad I won’t have to deal with the elements. Sometimes I’d still get some water pool up in the bow walkway but otherwise boat stayed dry.
    This is how ours generally looks once tightened...
    Mar 2020
    Denton, TX
    Yea that’s how ours looks now. The middle was a lot lower and it was pooling on either side with a hard enough downpour.
    --Justin
    2019 Moomba Makai
