Results 1 to 7 of 7
Thread: My Buzzin’ Speakers
03-03-2020, 06:07 PM #1Junior Member
- Jun 2017
- 2
My Buzzin’ Speakers
I’m having an issue with my dealer installed tower speakers on my ‘15 Mojo. They have a pretty good degree of interference, or buzzing. I’ve already plugged in an aftermarket attenuators in-line through the RCA plugs on my amp. That didn’t help at all. Any suggestions would be great.
03-03-2020, 07:23 PM #2Senior Member
- Oct 2016
- Tims Ford Lake TN
- 453
MLA will likely help you with a response. In the meantime, you can give him a head start by stating your grounding info. Do you have all components grounded at the distribution block in the passenger compartment?
2016 Mojo Surf
Raptor 400
1100 rear bags / 500 IBS / 600 LeadWake
Exile amps/tower - Kicker in-boat
FAE
03-03-2020, 07:56 PM #3
This issue is likely where they connected the new amp's B+ and B- ( B = battery) cables. Likely seeing a different voltage reference then the rest of the audio system. Once resolved, remove and toss those noise filters. Could be incorrect RCA's. Could be amp tuning, could be they used a line level converter off the back of the head, to gain an RCA plug.
03-05-2020, 02:10 PM #4Junior Member
- Jun 2017
- 2
Thank you both for your help!
03-11-2020, 09:07 AM #5
The biggest issue i have found when getting buzzing interference in the stereo is the stereo is grounded to the common ground buss the rest of the boat is.
If you have dual batteries you should set one up to be stereo only. This means all power and ground for the stereo only goes to this battery.
From Deck Power to amps, then your noise should stop.
As for charging the batteries you should have a Positive Selector switch to choose which bank is charging, being used, and or an ACR exp Blue Seas System 7623 ML-ACR Automatic charging relay.
Essentially when you start the boat, it will charge the starting battery to full then switch to your stereo battery automatically. Then when it senses the starter battery is below full again it will switch back and re-charge it.
I have been using this set up for over 10 years and never had an issue with a dead starter battery.
Also I run 2 AGM 6v Gell batteries for my stereo and an Ultima 12v gel battery for my main boat battery.
Feel free to PM me if you have questionsLast edited by mmandley; 03-11-2020 at 10:44 PM.
[COLOR="#696969"]
03-11-2020, 04:58 PM #6
Mike, good to see you back.
Gil Hebert
2014 Mojo
03-11-2020, 10:43 PM #7
