Results 1 to 6 of 6
    Aug 2019
    Default 2009 mobius lsv ballast install
    I have never written a thread before so bare with me. Hopefully this will help someone else out wanting to do the same thing. I was tired of throwing a pump over the side of my boat to fill my rear sacs up so I decided to plumb them in this winter and started project last weekend. I could not find a thread for this specific boat and set up so I pieced things together from pictures and watching the gravity III ballast upgrade on wakemakers site which i do not have I only have one center ballast bag. I ordered all my stuff from wakemakers and chose to go with reversible pumps. I will say one thing spend the extra money and use the plug and wake kit they sell I chose not to and ended up buying the same deutsch dtp connectors they use so pretty much shot myself in the foot there having to make all those connectors up. But ifYou don’t mind making the connections up or you can use different style connectors and order the wire from amazon. The only reason I used the same connectors is because I’m going to add there timers to system. also if you need a crimping tool for closed barrel connectors I got one off amazon literally 10 times cheaper than expensive ones and it worked fine not building an airplane over here it was called iswiss or something. I have an intake for each pump so i can fill my bags all at the same time so yes i drilled two additional holes in the bottom of my boat. yes i was nervous about this step. and still am because i havent put the boat in the water yet but i will update everyone on that later. originally i ordered two reversible pumps and was going to replace center bag aerator pump with reversable later but i did not like that all my intakes werent going to be in a straight line and one was going to be on opposite side of other two so i removed aerator pump and ordered my third reversable so now thru hull intakes are all on the same side and in straight line i believe one is 5" center to center and other is 4.5 I used 1” hose for fill lines and 3/4 for vent 3/4” hose is a lot easier to work with if you decide to go that route.
    Use a 1 1/16” whole saw instead of 1 1/8 if you go with 3/4 thru Hull fittings you can buy one on amazon some local hardware stores may have it mine did or wakemakers sells them as well. I decided to purchase a fuse block and go that route 1) it looks cleaner in my opinion and I only have two wires running from battery side of boat instead of 6 and I connected positive to battery switch that way the kids cant bump switches and turn them on by accident that is if the switch is in off position. I am aware that there is a positive and negative bus above the fuse block I installed but the positive side is powered by 10 gauge wire and I did not feel like tracing it through the bird nest of wires under dash to upgrade it. I went with 6awg wire to power fuse block that way I can add things later if needed. If you go with 1” ballast hose and use the quick release bag connectors you will need a heat gun like it says on wakemakers website. To mount my switches I decided to mount them right under the drivers seat there is a black plastic piece that unscrews to access the seat to take it off I just bought a piece of plexy glass from Lowe’s cut it and decided to mount switches there for now was easier then where I was going to mount them I can always move them if I want. If you have any questions let me know and I’ll try and answer them I will post the link to YouTube video.
    https://youtu.be/WicATAQ8FsU
    Items:
    WakeMAKERS 3M 4000 Marine Adhesive
    WAKEMAKERS 3M 4000 MARINE ADHESIVE
    Item #: 37003
    Quantity: 1
    Jabsco Ballast Puppy Reversible Pump w/Rocker Switch (88lbs/min)
    JABSCO BALLAST PUPPY REVERSIBLE PUMP W/ROCKER SWITCH (88LBS/MIN)
    Item #: 23003
    Quantity: 2
    WakeMAKERS Flow Rite 3/4" Elbow Quick Release Connector W742
    WAKEMAKERS FLOW RITE 3/4" ELBOW QUICK RELEASE CONNECTOR W742
    Item #: 33042
    Quantity: 2
    Fly High Bag Thread x 3/4" Flow-Rite Fitting W736
    FLY HIGH BAG THREAD X 3/4" FLOW-RITE FITTING W736
    Item #: 33036
    Quantity: 2
    WakeMAKERS Bronze Mushroom Thru-Hull Intake
    WAKEMAKERS BRONZE MUSHROOM THRU-HULL INTAKE
    Item #: 35001-340
    Quantity: 2
    Size
    3/4"
    WakeMAKERS Bronze Ball Valve
    WAKEMAKERS BRONZE BALL VALVE
    Item #: 35003-340
    Quantity: 2
    Size
    3/4"
    WakeMAKERS Reversible Ballast Pump Wiring Install Kit
    WAKEMAKERS REVERSIBLE BALLAST PUMP WIRING INSTALL KIT
    Item #: M10257
    Quantity: 2
    Ballast Pump
    88lbs/min Jabsco Ballast Puppy
    WakeMAKERS Flow Rite 1" & 1-1/8" Barbed Elbow Quick Release Connector W746
    WAKEMAKERS FLOW RITE 1" & 1-1/8" BARBED ELBOW QUICK RELEASE CONNECTOR W746
    Item #: 33046
    Quantity: 2
    Fly High 1" & 1-1/8" Flow-Rite Bag Fitting W743
    FLY HIGH 1" & 1-1/8" FLOW-RITE BAG FITTING W743
    Item #: 33043
    Quantity: 2
    WakeMAKERS Black Thru Hull Fitting
    WAKEMAKERS BLACK THRU HULL FITTING
    Item #: 36004-340
    Quantity: 2
    Size
    3/4"
    WakeMAKERS Ballast Hose - Black
    WAKEMAKERS BALLAST HOSE - BLACK
    Item #: 31001-100
    Quantity: 40
    Size
    1"
    Item #: 31001-340
    Quantity: 15
    Size
    3/4"
    WakeMAKERS Ballast Rocker Switch Cover - Right
    WAKEMAKERS BALLAST ROCKER SWITCH COVER - RIGHT
    Item #: 37014
    Quantity: 1
    WakeMAKERS Ballast Rocker Switch Cover - Left
    WAKEMAKERS BALLAST ROCKER SWITCH COVER - LEFT
    Item #: 37015
    Quantity: 1
    WakeMAKERS Threaded Hose Barb Connector
    WAKEMAKERS THREADED HOSE BARB CONNECTOR
    Item #: 19965
    Quantity: 2
    Hose Size
    1"
    Thread Size
    3/4"
    Tools:
    Drill
    1 1/16” wholesaw
    Crescent wrench
    Nut driver
    Heat gun
    Magnets (wife had some in her crafting area from a craft store hobby lobby IÂ’m sure Walmart has them theyÂ’re cheap)
    Blue painters tape
    May 2010
    Salt Lake City, Utah
    Nice job. I converted mine several yrs ago to the reversible pumps and it's a great upgrade. You can also look at adding a bag under the bow seats and plump that off of the center bag under the floor. That gives you another 500+ lbs in the bow.
    Scott
    2021 Craz
    1997 Sea Ray 190
    Aug 2017
    Nice, you should post that to Wakegarage.com as well.
    2019 Supra SL450
    Aug 2019
    Thanks I plan on adding the bow bag pretty soon and that was my plan to tie into center bag do you have a valve in case you don’t want to fill the bow up?
    Jul 2019
    Alabama
    I’m currently in the process of installing the wakemakers upgrade on my 07 LSV, anyone have a pic of where they mounted the pumps in the boat? I have a pretty good idea of where I want to put them but wanted to see if you guys had better ideas. Any help is greatly appreciated!
    May 2020
    Little Rock
    I can get Pics tonight and post, but I ended up putting one pump on Port side of Bilge area for front bag. Other two pumps fit up at front of engine right below where the hatch closes. I thought about the back, but too close to exhaust manifolds and keeps me from being able to change my impeller, which is a PITA anyway because of the little room i already have even before pumps went there.
    C. Andrews
    2004 Moomba Outback LSV
