Results 1 to 10 of 16
Thread: Key Replacement
    Default Key Replacement
    I bought a 2016 Moomba Monda used. It only has one ignition key. I would like to get a spare but can't find anything about this key on line. the logo on the key appears to say "CH". If anyone has any ideas, I would appreciate it. Thanks.
    Henderson, NV
    I would guess nothing has changed from a few years ago. looks like best bet is a new ignition switch. they are pretty straightforward to swap out.
    https://forum.moomba.com/showthread....lost-boat-keys
    https://forum.moomba.com/showthread....ion-key-blanks
    again these are pretty old posts so maybe something has changed but doesn't look like it.
    Mar 2003
    Springfield Missouri
    A decent locksmith can make a key.
    1998 Mobius
    310 HP PCM
    SOLD
    Thanks much to both!
    Sep 2005
    Claytor Lake, VA
    Should be a common key blank that is easy to duplicate.
    2005 Mobius LSV
    325 EFI
    Feb 2010
    Raleigh, NC
    Swapping out the ignition in my 2012 was a $20 part and a 5 minute job. Just FYI.
    Jeff
    2012 Outback V
    Aug 2018
    I found out that it is not a common key blank, there's a numeric code on the ignition I believe. Give that code to the dealer and they should have the key on hand.
    2016 Mojo surf edition
    1100lbs rear w/ 475lbs piggyback mid/ center 700lbs/ 500lbs IBS/ 600 lbs lead
    ACME 2315
    I got my for 10 from the local key master near my house
    my point - you do not need to go to officials to get the spare key
    Jun 2020
    Reno, NV
    Quote Originally Posted by David Burchfield View Post
    The CH key is the most common for RV and travel trailer locks. Check with an RV service center if your local locksmith doesn’t have one.
    Interesting note that I found out while shopping for our travel trailer is that the companies (keystone, etc. ) only use one key template for most of their builds. The CH 704 key is the most common, and companies will only use one cut. If you have a CH 704 key from a similar manufacturer, you can open doors on similar model years.
    So, changing an ignition might raise to higher priority now.
    Currently boatless
    2020 SA 450 Wife calls it White Cloud. Said it makes her feel "Classy"
    2017 Sanger V215sx. We call it Viagra because it's the little blue pill that gets everyone up (Sold)
    Aug 2020
    Middle Tennessee
    Same with Caterpillar equipment, literally all of them have the same key.
    2020 Supra SA
