Results 1 to 6 of 6
Thread: Trailer brakes
    Dec 2006
    Louisville, Colorado
    Default Trailer brakes
    I have a 2006 Mobius LSV on a single axel trailer. Does any one know how to adjust the braking force on the trailer? I need to increase the braking power.
    Feb 2007
    tacoma
    I dont think you can adjust the brakes but you could always call boatmate they should know. Talk to owen
    Feb 2006
    Birmingham
    I am in the process of putting the surge breaks back together. Somehow my master cylinder becam full of water, so I broke it down cleaned everything and ordered replacement parts. From everything I have seen, I have not seen any adjustments for breaking adjustments. What kind of problems are you having? Could your bypass valve be stuck and your breaks are not truly working?
    15 Mondo Surf Edition
    02 LSV - Traded In
    Jul 2003
    I don't think you can adjust them either. The only option that I know of would be to convert them over to electonically controlled brakes and use a controller in the cab of the vehicle. However, I imagine that would be a pretty detailed and expensive project.
    Oct 2005
    Central FL
    Can I ask the simple question ...
    "Why?"
    Even with the brakes out, your tow vehicle should be able to handle the process itself. The trailer brakes are "assist" brakes. If you are having problems, and they are not working, then take them to the dealer, they are under warranty and they will be repaired for free.
    What are you towing with ?
    -Joe
    Dec 2006
    I am towing with a 2004 Toyota 4 Runner. I have talked with a dealer and they think I need to bleed the brakes. I did contact BoatMate and they recommended the same thing. I will let you know if it works.
    Thanks for the help
  1. Trailer brakes locked
    By SEARK in forum Service & Repair
    Last Post: 08-26-2007, 03:17 PM
  2. Trailer Brakes
    By TN_Boarder in forum Service & Repair
    Last Post: 06-26-2007, 07:03 PM
  3. trailer brakes
    By Gharvin in forum Service & Repair
    Last Post: 08-03-2006, 05:16 AM
  4. Trailer Brakes
    By in forum Sales & Information
    Last Post: 05-28-2003, 06:37 PM
  5. Trailer Brakes
    By Catdog1 in forum Boat Owners
    Last Post: 04-24-2003, 09:08 PM
