Results 1 to 6 of 6
Thread: Muffler Drain Bolt Question
11-20-2019, 02:06 AM #1
I pulled the drain bolt on my 2011 LSV a couple of weeks ago. I tried putting it back in today and it threaded, but seemed to strip or not tighten fully. Anybody have experience with this? I'm thinking I will pull the hoses off the muffler and see if I can see any issue internally. It didn't seem to get a good seal when I replaced it.
I've done this in the past without issue. Not sure what happened today. Thoughts?2011 Mobius LSV
Ron
11-20-2019, 09:24 AM #2
Why didn’t you just disconnect the connector hoses between the exhaust manifolds?
Sent from my iPad using Tapatalk2017 Moomba Craz
11-20-2019, 09:34 AM #3Senior Member
- Sep 2005
- Claytor Lake, VA
- 598
The muffler drain bolt is threaded into the fiberglass body so I am always careful how much force I use when tightening it. The bolt has a rubber gasket to provide a seal. You could tap the hole to the next size bolt or use a metal roofing screw with a gasket.
2005 Mobius LSV
325 EFI
11-20-2019, 01:51 PM #4
Those things are a bear to get off. The drain bolt is there to make it easy.
2011 Mobius LSV
Ron
11-20-2019, 01:55 PM #5
11-21-2019, 10:13 AM #6Junior Member
- Jul 2017
- Central Wisconsin
- 15
