Results 11 to 20 of 32
    Sep 2017
    Hanover, VA
    WD-40 and a paint can opener pops it right out.
    2018 Moomba Mojo
    Mar 2019
    First year owning the boat so replaced mine this fall...couldn’t get the impeller slipped out so unbolted the entire pump (3 Allen bolts on engine pulley and 1 on the “holder”)
    Sep 2005
    Claytor Lake, VA
    I also found removing the entire pump easier and allows more room to get a grease gun on the rudder zerk fitting. I use 303 to free the impeller, coat it in Vaseline and put it in a zip lock for the winter.
    2005 Mobius LSV
    325 EFI
    I would highly advise against coating an impeller in a petroleum based grease. if you feel the need to coat it in anything, say to keep it from "drying out", for storage, use 100% silicone.
    Apr 2013
    Knoxville TN
    I think when you buy the ballast impeller kits they come with a small tube of glycerin grease, but I do not recall ever viewing that in a big box store, but you can find silicone multi purpose water repellent grease.
    2018 Supra SL400
    Sep 2005
    Claytor Lake, VA
    I've used both Vaseline and silicone grease and didn't see any difference in impeller life. Main benefit of removing the impeller from the pump is to relax the fins.
    2005 Mobius LSV
    325 EFI
    Likely do, for the initial installation. But most would likely not have any left for coating and storing a removed impeller at the end of season.
    Quote Originally Posted by VA LSV View Post
    I understand the thoughts for pulling it. The concern is that petroleum based products can deteriorate and swell the impeller material, if its not designed for constant contact with that type of grease.
    Sep 2005
    Claytor Lake, VA
    Been doing it this way for 14 seasons with no swelling or deterioration.
    2005 Mobius LSV
    325 EFI
    Sep 2005
    Claytor Lake, VA
    Remove impeller, coat with a thin film of Vaseline and store in an airtight bag is part of the winter layup procedure in the Indmar manual that came with my boat.
    2005 Mobius LSV
    325 EFI
