Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
    May 2018
    Waynesville, Ohio
    Default Water Pump Impeller Removal
    Anyone have any good tips to remove the raw water pump impeller? They always seem to pull out hard, but I am really struggling to get it out this year. With all the smart engineers we have in this country you would think they could put a part that needs replace each year in a more accessible spot!
    2018 Moomba Craz
    6.2L Raptor 400
    6 Pump Ballast, Autowake 2.0, Flow 2.0 Surf System
    OJ 15x13 Wake Prop
    Digital Cruise Pro 3 (paddle wheel)
    Wetsounds Rev 10's
    2005 Supra Launch 22SSV - Sold
    May 2018
    If you have cover off, spray impeller with WD40 then take need nose pliers and grab a rubber vane and wiggle it, work your way around in one direction grabbing a vane and wiggling, it eventually pops free
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Apr 2013
    Knoxville TN
    WD40 soak. Then bumped the motor a few times. Came right out with needle-nose pliers on my SL.
    Yea, weird spot with th a plastic cover back there.
    2018 Supra SL400
    Apr 2013
    Knoxville TN
    Trick was getting that first 1/4" to move.
    2018 Supra SL400
    May 2018
    Waynesville, Ohio
    Good tip. Thank you. I got it out after some cussing and snorting. . It was really stuck in there this year. I have never had that much trouble getting it out. Maybe I am getting weaker. Ha ha.
    2018 Moomba Craz
    6.2L Raptor 400
    OJ 15x13 Wake Prop
    Wetsounds Rev 10's
    Impeller puller tool.
    May 2018
    Waynesville, Ohio
    Didn’t even know they made one. Good to know! I am all about having the right tool for the job.
    2018 Moomba Craz
    6.2L Raptor 400
    OJ 15x13 Wake Prop
    Wetsounds Rev 10's
    Aug 2017
    2 paint can openers to pry it out.
    2019 Supra SL450
    2018 Supra SL550 with 850lbs of lead wake
    2017 Supra SA400 (Sold)
    2016 Moomba Mojo Surf Edition (Sold)
    2017 Ford F250 Super Duty (Sold)
    2019 Ford F250 Super Duty (Sold)
    2021 GMC Denali 2500
    Soulcraft Vodoo
    Soulcraft Jordi Pro
    Soulcraft Super AV
    Phase Five Matrix
    Apr 2013
    Knoxville TN
    Discount Marine @ $34 to $36 is a good deal. I assumed $100 for the tool.
    2018 Supra SL400
