Thread: Wake Plate Noise
10-25-2019, 03:14 PM #1
Wake Plate Noise
I have a new 2019 Moomba Craz. When the boat is in the water in idle, it makes a loud noise. It does go away after the throttle moves forward. My dealer tells me that it is the exhaust hitting the wake plate. I had a 2016 Moomba Craz, and it made the same noise. Has anyone experienced this issue, and is there a fix?
10-25-2019, 04:30 PM #2
I've never noticed that in our 17 craz
10-25-2019, 07:56 PM #3
Yep mine does that as well. You can buy plastic washers and add them to reduce the play. It does help.
10-25-2019, 07:57 PM #42018 Supra SA400 aka The Ron Burgandy
2011 Sea-Doo Wake 155
10-26-2019, 05:13 PM #5
Composite shims work well if you have areas to use them. I used them on my last boat. Lowes or HomeDep.
Sent from my P00I using Tapatalk2018 Supra SL400
10-28-2019, 01:30 PM #6Senior Member
- Oct 2016
- Wisconsin
- 311
I have the same thing (i think) on my 2019 mondo. Couldn't figure it out until now but makes sense. Sounded like ballast was pumping out like a grumble coming from the back of the boat at idle. As soon as i hit the throttle it goes away.
2019 Mondo
11-12-2019, 04:29 AM #7Junior Member
- Nov 2019
- 2
