    Dec 2006
    Thomasville, GA
    Default Gear/Throttle Lever
    Here I am starting another thread with a question but where else can you get this quality feedback. My gear/throttle control seems to be hard to get into gear. Once it goes in it operates smoothly, just right at the beginning coming out of neutral. The selector on the transmission is also smooth and moves with ease. Can these be greased or is it in need of an adjustment? Anyone had this before?
    Feb 2006
    Hamden Ct
    When I had this trouble it turned out to be a cable and when it was replaced it worked fine. Just my $0.02
    Aug 2004
    Lake Hickory, North Carolina
    You can grease the ends that are exposed, extend the throttle one way, coat o grease, the other way , coat o grease, werk it a couple times. That may help. Also a small amt o grease on the connections and links.
    Hope this helps
    B
    Dec 2006
    Thomasville, GA
    I greased the ends up at the front like you said B. Works smooth as silk.
    Aug 2004
    Hell yeah!
    B
  1. 08 LSV....is it throttle by wire or cable?
    By 2thdoc01 in forum Service & Repair
    Last Post: 04-24-2008, 04:38 PM
  2. Throttle cable problems with top speed?
    By pcm2a in forum Service & Repair
    Last Post: 08-14-2007, 01:08 PM
  3. stiff throttle
    By AZ_Calling in forum General Chat
    Last Post: 08-01-2005, 11:41 AM
  4. Throttle Lever
    By mseidelch in forum Service & Repair
    Last Post: 07-17-2005, 01:26 PM
  5. Need Help with Throttle
    By Wakeboard2222 in forum Service & Repair
    Last Post: 06-26-2004, 01:06 PM
