Results 1 to 10 of 17
    Default Changing coolant on Raptor
    How difficult is it to drain and replace the coolant in the Raptor engine?
    Is it as simple as taking off 2 hoses in the link below and refilling?
    https://www.indmardealersupport.com/news-letter.php
    Aug 2011
    Commerce Lake, MI
    Why do you want to do that?
    2017 Moomba Craz
    Changing coolant is part of regular maintenance.
    Quote Originally Posted by Stazi View Post
    Aug 2011
    Commerce Lake, MI
    Unless you have many hundreds and hundreds of hours (500+) I don’t see the need.
    2017 Moomba Craz
    Oct 2010
    Lake Wylie NC Area
    I think they come with extended life Dex-Cool. Whats the manual say for service interval?
    Thanks for the input.
    I see the need and will change it out. I'd rather not tow it in to the dealer so was hoping to do it myself.
    500+ hours for me is about 10 years of use.
    May 2018
    They come with propylene glycol and PG is typically not long life antifreeze. 2 years is correct.
    2021 Supra SA 400
    2018 Supra SA 400 (SOLD)
    Michigan
    Every 2 years.
    May 2018
    Waynesville, Ohio
    Quote Originally Posted by JHCMondo View Post
    Every 2 years.
    Did you do this yourself? I am getting ready to replace mine? Was it as simple as the link indicated, or do you have any tips or tricks?
    2018 Moomba Craz
    6.2L Raptor 400
    6 Pump Ballast, Autowake 2.0, Flow 2.0 Surf System
    OJ 15x13 Wake Prop
    Digital Cruise Pro 3 (paddle wheel)
    Wetsounds Rev 10's
    2005 Supra Launch 22SSV - Sold
    Very easy, so do it yourself. The only unexpected thing is not all the coolant drained out, I think there will always be some that can't drain.
    It survived winter and this spring it ran fine with normal temperatures and no leaks.
    Quote Originally Posted by jcarter20 View Post
